Hill Climbing Primer
/ Hill Climbing Primer #201
Back Flips:
Enough torque, enough traction and the tractor will rotate around the rear axle. Don't mater how low you hitch.:thumbsup:
Oh come on ! It matters WHICH WAY it rotates ! If the pull point is below the axle, that rotates the tractor to put more weight on the front wheels. If the pull point is above the axle it rotates the tractor to put less weight on the front wheels. No way around those facts. Physics and farmers must mix...
Your 25 horse Ford is not the best tool for that job.
Can you expound, please? I can't afford the "best" tool for this job, but was hoping to have found an adequate one :(
/ Hill Climbing Primer #203
Last comment on this "off topic"
If I wish to calculate the "flipping over" lever arm length on the Fordson, which has large diameter, direction reversing bull gears inside the rear end, do I measure the length of the pinion shaft to the front of crankshaft? Or is there some other measured length that is more direct? The E27n is not very powerful, something less thgan 30HP I'm sure, and it's a Very heavy tractor with cast iron front wheels. Even the radiator top tank is cast iron and having removed it several times in the past 35 years, I know it is VERY heavy. I'm just wondering how to sum up the leverage ratio so I won't exceed the "flipping point". I have had the front end clawing air on a number of occassions. It seemed like it was pretty controllable, but I really should have a better idea of where the leverage is measured.
http://i1.ytimg.com/vi/1G5g_HwgD24/hqdefault.jpg
da ja vu
http://www.tractorbynet.com/forums/owning-operating/215952-preventing-tractor-back-flip.html
Ah, I see you found the tread from some years ago. In that thread there is a post by a very well educated mechanically knowledgeable ( far beyond my abilities ) Maritimer. He will not agree with you.
On your tractor just start with the horsepower delivered to the clutch and then calculate the rotational forces involved at each gear engagement point till you get to the tire. The initial rotation point is fixed to the tractor frame. You should easily be able to do the calculations as the tractor rotates about the rear axle!
/ Hill Climbing Primer #204
Works if you use a toy tractor and real levers. Put an engine and rear wheel drive in that tractor and observe what happens.
Now what was this about farmers and physics???
/ Hill Climbing Primer #205
Still too muddy to go down there, I've been "practicing" on a less steep hill in a drier area and have found success chaining logs to the bucket, engaging the 4WD, and keeping the bucket close to the ground with a ready hand on the FEL down lever for when the back end gets light. I'm not sure how that's going to equate to the steeper climb out of the area discussed here though. I was hoping to give it a go this weekend but am helping a friend move today and a family member with a roof tomorrow. Darn, I hate it when life gets in the way of tractor time ;)
I'm pretty much set on getting a log arch for the bigger logs the FEL won't lift like that 20+ inch walnut.
Glad to see you are educating yourself on FEL use. Sounds like you are approaching it with the necessary caution. Anytime I'm carrying a load with the FEL I have my hand on the joystick. Anytime!!!! I also manage my speed cautiously.
Additionally when you chain an item to the bucket or when using a Grapple the dynamics change. You can't get loose from the item by simply dumping.
So be alert and very conscious of your surroundings and you'll be fine. I've carried loads hundreds of hours with the FEL but I still get into situations ocassionally where my heart skips a beat. The more you work in these situations the more you'll bond with your tractor to the point you can feel a hazard coming.
/ Hill Climbing Primer #206
Right back to the point.
IF the tires and wheels are not allowed to turn relative to the tractor chassis, leaving only the reaction at the ring and pinion, that long long lever, does absolutely NOTHING.Yet if a lever is applied at the same locked tires/wheels, Over it goes ;-)
Simple
I suppose we could move up the line and say that is the piston pushing on the connecting rod that causes the turn over, for there are the "head waters" of all subsequent reactions.
But alas, the cranks on "most" tractor engines are arranged 90 degrees to the desired reaction, and this just leads to confusion for the "pinion climbing" to explain.
What is needed is direct coupled steam power. Maximum torque at minimum revs. No confusion regarding the gearbox there ;-)
Might as well describe what is really taking place ....;-)
If the load lever is longer than the pull lever, no amount of pull will tip the tractor over backwards. For it is the pull that produces the load. Despite the futile antics within the differential.
There he went again,,,, welded the rear axle shafts to the housing again..... :confused3:
/ Hill Climbing Primer #207
I'm wondering if the climbing pinion gear debate will be settled before I get the logs out of the bottom land ;)
I'm guessing not...... :)
/ Hill Climbing Primer #208
I suggest you go back and reread Egon's statement that you referred to. Key point is "enough traction".
/ Hill Climbing Primer #209
I agree. The challenge is finding a way to do the job with the tool you have, not run out and buy a bigger tool.....
/ Hill Climbing Primer #210
Very understandable -- we cannot all just go out and buy some very large machine. What I meant was it would be fairly easy with a larger machine and grapple hooks on the loader. With a 25 horse-sized machine (weight and everything considered) it is much more difficult. And worse yet a lot more risky. That's what I meant about "size matters." What's best for each one's circumstances of course differs. I just think the whole job can be a lot more dangerous with the 25 horse Ford than it would be with say a 60 horse 4WD of some sort. Many people have spoken and I agree with most of them. Assuming this is not something you do every day, and you just need to get it done, I favor pulling or carrying the logs with the loader to a pile just below the steep part. Then pull them up over the steep with your machine and a cable or chain. Good luck with it all !
/ Hill Climbing Primer #211
Well, I know the log arch and snatch block I suggested a few days ago will work with what he has.. Would probably work with a good heavy garden tractor.:D
/ Hill Climbing Primer #212
Correction guys: 25' rise over 75' travel is a 33% slope NOT a 33 DEGREE slope. You cannot climb a 30 degree slope at all. But that's just a terminology point.
NO. NO. The slope is 18 degrees and he has 4wd and plans to carry them. Do not back up. Engage diff lock when theres no or only a low/slow difference in wheel rotation. Carry low. Dont work when muddy.
larry
We got thru this early.
/ Hill Climbing Primer #213
Course it matters which way it rotates -- the wheels that is. ... Now, - Physics says that a pull point below tire contact rotates the tractor to put more weight on the front wheels. Pull above the ground and the tractor can backtip.
larry
/ Hill Climbing Primer #214
No. The key point is "Dont matter how low you hitch". Falsifies Egons whole statement.
/ Hill Climbing Primer #215
Try this: instead of listening to a bunch of opinionated old farts like us, go to the manuals on the first 5 tractors you pick at random. Open and read what it says about towing and Warnings. Every single one will tell you, caution you, to tow with points on the tractor BELOW the center line of the rear axle. The danger is potentially tipping the tractor over backwards in extreme cases if the tow point is above the axle. That is why ALL drawbars are located below center line of the axle. It is obvious to me and most of the readers. If not, go ask the manufacturers. And if that still leaves you feisty and wanting to argue, go to Nebraska Tractor Test Laboratory, University of Nebraska, Lincoln Nebraska 68583-0832 and ask them. They are the only non-profit tractor test lab in the US. They have email at tractortestlab@unl.edu . The End.
/ Hill Climbing Primer #216
Awww Larry,,,, I thought we had covered this already?? ;)
If the rear tires do not lose traction and the drivetrain has the power to continue to turn the pinion and the load does not move, the tractor will do a wheelie, "dont matter how low you hitch" That is a true statement and all of the analysis given by yourself and CalG proves it. :)
/ Hill Climbing Primer #217
larry
You cannot tip the tractor backwards by pulling at any level between the ground and the midline of the axle for the following reason: there will never be enough traction for the rear tires.
/ Hill Climbing Primer #218
Your last few words is the point of contention. There are those that say it can NEVER tip over backwards even if the rear tires maintain traction. You last comment is the truth. The tractor will lose traction and thus not tip over backwards. Depending on application you may experience a loss of control momentarily, but no tip over backwards.
/ Hill Climbing Primer #219
OH Now I see, You mis-understand.
I do fully embrace the front end lifting when power is applied and resistance is present.
But the reaction occurs at the GROUND. Not at the pinion. As I have repeatedly stated. The pinion forces are taken out inside the transmission. It is only when the WHEELS try to move relative to the ground that ANY forces appear outside of the tractor. For the WHEELS /TIRES are the ONLY part of the tractor that can apply "tractive force". Without that, no other forces can be generated that will disturb the motionless tractor.
Silly to believe otherwise
Absolutely!.
Amen brother. Correct.
CATERPILLAR TL642D TELESCOPIC FORKLIFT (A62129)
CATERPILLAR TL642D...
2021 PermaGreen Ride-On Speader-Sprayer (A64194)
2021 PermaGreen...
2025 Greatbear Rachet Tie Down & Flatpack Tool Box (A61567)
2025 Greatbear...
New/Unused Quick Attach Pallet Forks (A65583)
New/Unused Quick...
2015 PETERBILT 579 TRI/A DUMP TRUCK (A59914)
2015 PETERBILT 579...
Peanut Wagon (A64127)
