Help! Grease Coupler won't fit
/ Help! Grease Coupler won't fit #1
flienlow
Snohomish,WA
Kubota BX25D, Kubota U25 Mini Excavator
I have a Kubota U25 Mini with a Thumb, and use a Lincoln Air Gun to grease it. Everything is fine except for 1 fitting on the thumb. The grease coupler is too big to fit in the hole that the Zerk is recessed in. I went to tractor supply and a few other places to see if I could find a "thinner" Grease Coupler, but I was unable to. Any ideas?
/ Help! Grease Coupler won't fit #2
Grind down the coupler so it'll be smaller and fit.
I didnt know those Grease needles would work. I will give that a try. Thanks.
/ Help! Grease Coupler won't fit #6
Nipple and a coupling will bring the fitting out closer unless movement closes off the hole in question. A picture would help on ideas.
Ron
adding to. you may need to physical move the backhoe to access a zerk.
TIP: twist greese gun end say approx 1/2 a turn if will not fit on or will not come off.
2017 KENWORTH T680 TANDEM AXLE SLEEPER (A59905)
2017 KENWORTH T680...
Mini John Deere Truck (A55853)
Mini John Deere...
light tower (A60352)
3-Gang Reel Mower Pull-Behind Tractor Attachment (A59228)
3-Gang Reel Mower...
2017 Subaru Impreza AWD Hatchback (A59231)
2017 Subaru...
2007 CHEVROLET 3500 DUALLY 4X4 DIESEL TRUCK (A59575)
2007 CHEVROLET...
