Help! Grease Coupler won't fit
   / Help! Grease Coupler won't fit #1
flienlow
Snohomish,WA
Kubota BX25D, Kubota U25 Mini Excavator
I have a Kubota U25 Mini with a Thumb, and use a Lincoln Air Gun to grease it. Everything is fine except for 1 fitting on the thumb. The grease coupler is too big to fit in the hole that the Zerk is recessed in. I went to tractor supply and a few other places to see if I could find a "thinner" Grease Coupler, but I was unable to. Any ideas?
   / Help! Grease Coupler won't fit #2
Grind down the coupler so it'll be smaller and fit.
I didnt know those Grease needles would work. I will give that a try. Thanks.
   / Help! Grease Coupler won't fit #6
Nipple and a coupling will bring the fitting out closer unless movement closes off the hole in question. A picture would help on ideas.
Ron
adding to. you may need to physical move the backhoe to access a zerk.
TIP: twist greese gun end say approx 1/2 a turn if will not fit on or will not come off.
Schulte XH1500 Series 4 15ft Pull-Behind Batwing Rotary Brush Cutter Tractor Attachment (A59228)
Schulte XH1500...
ExMark Vantage 48in Stand-On Commercial Mower (A59228)
ExMark Vantage...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59228)
2006 iDrive...
2012 JACK COUNTY TANK 130 BBL STEEL (A58214)
2012 JACK COUNTY...
BOBCAT T300 SKID STEER (A60429)
BOBCAT T300 SKID...
2018 KOMATSU WA320-8 WHEEL LOADER (A60429)
2018 KOMATSU...
