Help! Grease Coupler won't fit
/ Help! Grease Coupler won't fit #1
flienlow
Snohomish,WA
Kubota BX25D, Kubota U25 Mini Excavator
I have a Kubota U25 Mini with a Thumb, and use a Lincoln Air Gun to grease it. Everything is fine except for 1 fitting on the thumb. The grease coupler is too big to fit in the hole that the Zerk is recessed in. I went to tractor supply and a few other places to see if I could find a "thinner" Grease Coupler, but I was unable to. Any ideas?
/ Help! Grease Coupler won't fit #2
Grind down the coupler so it'll be smaller and fit.
I didnt know those Grease needles would work. I will give that a try. Thanks.
/ Help! Grease Coupler won't fit #6
Nipple and a coupling will bring the fitting out closer unless movement closes off the hole in question. A picture would help on ideas.
Ron
adding to. you may need to physical move the backhoe to access a zerk.
TIP: twist greese gun end say approx 1/2 a turn if will not fit on or will not come off.
MORBARK WOOD HOG 6400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
2013 CARRY-ON TRAILER 14 T/A DOG HOUSE (A63569)
2013 CARRY-ON...
Transfer tank (A61567)
John Deere 5101E Tractor w/ John Deere Loader (A64047)
John Deere 5101E...
HOMEMADE PORTABLE PROPANE SMOKER (A63745)
HOMEMADE PORTABLE...
14ft Flatbed Truck Body (A59228)
14ft Flatbed Truck...
