Had to share this find from Harbor Freight
   / Had to share this find from Harbor Freight
   / Had to share this find from Harbor Freight #12
That's a good price for the adapter bushings. I paid about the same, maybe a little more from Northern Tool.
Is that the correct bushings to get? They have a few to choose from and im not sure. I have also read where people use regular lynch pins along with bushings cut from metal pipe in the right diameter.
   / Had to share this find from Harbor Freight #14
Those are correct assuming you have "regular" Cat 1 pins on your implements. Pipe and lynch pins works fine too assuming you can find pipe with the correct dimensions for both ID and OD. I briefly tried and gave up. The ready-made adapters were just a whole lot simpler and any cost difference was negligible.
I thought about NOT using the adapters with the drive-in roll pins so that it would be a little easier to convert my implements back to non-QH. But then I thought that the only reason I would do that was so that an in-law or neighbor could borrow the implement. And do I REALLY want to loan out an implement?
2018 Chevrolet Silverado 4x4 Service Truck, VIN # 1GC1KUEY2JF129960 (A57453)
2018 Chevrolet...
2014 Ford Fusion Passenger Car, 2.5L Engine - Only 90,875 Miles (A56438)
2014 Ford Fusion...
New/Unused 2 Post Car Lift (A57453)
New/Unused 2 Post...
10 Lug Wheels Full Set (A57453)
10 Lug Wheels Full...
207282 (A52708)
207282 (A52708)
2018 Grove 700E 60T Crane (A60460)
2018 Grove 700E...
