Had to share this find from Harbor Freight
   / Had to share this find from Harbor Freight
   / Had to share this find from Harbor Freight #12
That's a good price for the adapter bushings. I paid about the same, maybe a little more from Northern Tool.
Is that the correct bushings to get? They have a few to choose from and im not sure. I have also read where people use regular lynch pins along with bushings cut from metal pipe in the right diameter.
   / Had to share this find from Harbor Freight #14
Those are correct assuming you have "regular" Cat 1 pins on your implements. Pipe and lynch pins works fine too assuming you can find pipe with the correct dimensions for both ID and OD. I briefly tried and gave up. The ready-made adapters were just a whole lot simpler and any cost difference was negligible.
I thought about NOT using the adapters with the drive-in roll pins so that it would be a little easier to convert my implements back to non-QH. But then I thought that the only reason I would do that was so that an in-law or neighbor could borrow the implement. And do I REALLY want to loan out an implement?
2006 Sterling Acterra Rollback Wrecker Truck (A59814)
2006 Sterling...
25 TANDEM DUAL GOOSENECK TRAILER (A55745)
25 TANDEM DUAL...
2023 Kubota U48-5 Compact Excavator with Angle Blade and Hydraulic Thumb (A56436)
2023 Kubota U48-5...
2014 Chevrolet Silverado1500 Pickup Truck, VIN # 1GCNCPEH0EZ393232 (A57453)
2014 Chevrolet...
2022 JOHN DEERE 624P WHEEL LOADER (A52707)
2022 JOHN DEERE...
Margaritaville 5 O' Clock Somewhere Sign (A57454)
Margaritaville 5...
