Grapple Advice
/ Grapple Advice #21
No I have not used the SGC0554 and didn't need to. I purchased the Homestead Implements grapple. One doesn't need to use something to see that it's not built as well as something else. The HSI is made of Hardox 450, has thicker metal and a better design than the LP SGC0554.
I guess Kubota has got it wrong with their partnership with Land Pride implements and how they are designing them to work together with thier tractors. All I can really go on is my experience with the Land Pride grapple I have which is heavy duty and works as intended. Not one issue with it and used hard for multiple years doing heavy work. We can just agree to disagree. They are not a sub-par grapple. Maybe not the best but they are built with quality and do exactly what they are intended for and designed to work with the OP's Kubota tractor.
I am also not going to talk down to the Homestead and Catawba grapples. I am sure they are built well also. The Catawba grapple is right much heavier and the OP will lose some lifting strength. Also, we are not talking about heavy machinery. These are small compact tractors with limited hydraulic power. They are only going to do and lift so much anyway.
/ Grapple Advice #22
jeff93I66's post got me to thinking about my experience with the L2501 w/MTL grapple. It is great for picking up limbs and smaller brush, but the limited load carrying capacity of my L2501 relative to larger tractors forces me to have to cut the tree trunks into more sections to move them which means more chainsaw work. The tree services that use skid loaders can get away with less cutting because their skid loaders can carry larger sections.
There are multiple things to consider. The grapple, the FEL capacity, how dangerous it may be to cut the trees, and one's own physical condition to do this kind of work.
If the OP has a bunch of trees, the great thing about a grapple is it makes it a lot easier to move a lot of limbs reducing the amount of physical work required considerably.
/ Grapple Advice #23
There is an implement company - ANBO - about 70 miles north of me. I seriously considered them making a grapple for me. They will make whatever you want - out of whatever you want - as long as it is engineeringly sound. They make some really HD industrial implements also.
/ Grapple Advice #24
Simple SS expanded metal welded to front guard. Used a 3”x5” angle iron on bottom to prevent sticks from come up to damage grill. Adds strength also. An often over looked entry point. Added a receiver hitch but hasn’t been very practical with the FEL.
My 30+ year old skid-steer grapple has been a well used blessing on the farm. Tough and heavy. Its tines and teeth bypass each other. In contrast the 54” long bottom wicked tines and teeth touch. Can pick up a pencil and write my name. Handy for picking up smaller limbs or rocks that would require hand work. Less getting on/off tractor. With the B26 size and maneuverability, it really feels like an extension of your hand.
/ Grapple Advice #25
I'm sure it would be very expensive to have a professional cut up the trees and dispose of them.
I'm 77 years old -- but I think it's doable.
I am 77 years old too. We are both too old to be operating heavy saws. I practice Yoga twice per week, so for age 77 my balance is good. But not good enough to chance falling or fainting onto a revved up chainsaw.
Not to mention aneurism, stroke, heart attack, atrial fibrillation, heat exhaustion, dehydration.......
What is the driving time from your land to a hospital with a quality Emergency Room?
All good points jeff9366. On the other hand, me being past 83, I would relish the opportunity to play with a grapple on my own land, and on my own schedule. I suspect ahenthusahenthus could actually hire the work out much cheaper than buying equipment and doing it himself.
Sure, one can, and eventually will, get injured.And healing just gets slower. BUT - I'd rather die doing something really fun and worthwhile than sitting in front of a TV all day.
Good advice to ahenthusahenthus - have fun but be carefull. Live for today; tomorrow may never come.
ps More good advice - Get a grill guard first!
/ Grapple Advice #26
Logs and Grapple tip:
You don't always have to LIFT logs! Most times you can just cage the log and roll it out of the way.
I have used two different style grapples recently. This was the best lesson I learned while cleaning up [old] storm damage.
/ Grapple Advice #27
I think you misunderstood my point. I was not saying that LP doesn't make quality equipment. I was stating that for this specific grapple and price point, there are better options for basically the same $.
/ Grapple Advice #28
I have an Armstrong Ag BGR Mini 60" Brush Rake Grapple which clocks in at 400 lbs.
I've used it to transport lumber, load trash, brush, tree trunks, and help get 55 gal. barrels out of my truck.
Never had a problem... except once.
I have the SSQA on my FEL and once while clearing debris on a trail a stick came through and pushed the lever up on one side of the SSQA lock. When I brought the grapple down it disengaged on that side and fell off on the next lift. It was a real challenge getting that grapple back on the tractor in that tight space.
I haven't done it yet but I'm considering putting a chain or something between both locks to prevent this in the future.
/ Grapple Advice #29
At least get some quotes and advertise on facebook groups etc to see if you can get someone else to do it cheaper. You might be surprised. You can spend your time working elsewhere and make money while they clear the trees. If you spend a week or two clearing trees, that is time lost for other things.
Also, you may want two chainsaws, one for cutting and the other to free the first after it gets pinched.
/ Grapple Advice #30
Better 2-3 orange plastic chainsaw wedges and a 4-pound hand sledge.
An ounce of prevention is worth a pound of cure.
2016 Case CX55B Midi Excavator (A60352)
2016 Case CX55B...
2025 AGT Industrial SDA-140W (A60463)
2025 AGT...
2022 CATERPILLAR 262D3 SKID STEER (A62129)
2022 CATERPILLAR...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
24in pin on tooth excavator bucket (A61307)
24in pin on tooth...
Topcat SSSCR72 (A60463)
Topcat SSSCR72...
