Good morning!!!!
   / Good morning!!!! #155,801
One time on a small bearing used paint can opener that has the small hook for prying up the lid to get under the bearing and then hammer against the handle
   / Good morning!!!! #155,802
Still think the grease method should work if you can find a dowel with close fit.
Let me know if you need more ideas?
   / Good morning!!!! #155,803
69° F and no rain
9-11, day of remembrance. Remember what a different country/world we lived in 21 years ago. I miss those days.
Not a busy day planned. Watch some football. Maybe the season ends Bucs vs Patriots with Tom winning another ring and can retire.
Prayers for all
Be safe
Have a great day
   / Good morning!!!! #155,804
Prayers for all
Be safe
Have a great day
My sentiments exactly on both points (y) (y) (y)
   / Good morning!!!! #155,805
Now it does not have be grease you stuff into the cavity. It can be potatoes or similar cut into pieces and mushed in there and then use the dowel. It will generate back pressure without escaping in the oil channel
   / Good morning!!!! #155,806
53°F and light rain this morning, only going up to 71° today. Still misting a bit, but looks like the proper rain is finished with us and has moved on.
We have bungies on the deflectors on the rider and the zeroturn. The rider is always up, but the ztr really doesn't have a good place to hook it to hold it up. I've been thinking about just removing it, or maybe modifying it to only cover the top of the chute hole.
Soybeans, indeed, wngsprd. Most around here have started to turn this past week, but that field is still very green.
Also in agreement on noise, Drew, and not just on Sunday mornings. Most people don't want to listen to whatever someone else is blaring. As a Goldwinger, I've always found this annoying. I turned on the stereo when I bought the bike in 2012 to see if it worked, and haven't had it on since. For me, listening to music while riding spoils the ride. Same with people who have loud music playing while out paddling on a river or lake.
Not much planned for today, certainly not outside. Need to do a couple of online assessment tests before round two interview, write a one page response to a quality scenario they provided, and put together a PowerPoint presentation on it for the meeting with the VP and Director of Operations. May as well get that all done today. Second interview is Thursday.
Good morning, gents.
   / Good morning!!!! #155,807
I was mowing the field yesterday going full speed and hit some bumps pretty good. Fortunately back is ok. I put the spring suspension under my seat which helps.
Y’all stop hurting yourselves.
Being only 5 acres I don’t need much of a map, but mine is marked as
Across the creek
Along the creek (this side)
The field
Around the house.
Got the new power supply installed in church computer last Wednesday, so was able to stream again today. FB dropped the stream half way thru, not sure why. During class the batteries in microphones went dead and I had to change them. I filled in as song leader as the person scheduled today got the alligator bite.
.5” of rain so far.
On way to service a vehicle was laying on it’s side, just a mile down from the house. It took out a pole. Cop was sitting there.
On way back from service noticed another pole sheared off just 1/2 mile further up.
   / Good morning!!!! #155,808
The problem with the grease method is that it just oozes out of the oil passage.... can't build any pressure.
2017 FORD F150 REG CAB LONG BED 4X4 (A52577)
2017 FORD F150 REG...
New/Unused 30ft x 65ft x 15ft Storage Shelter (A51573)
New/Unused 30ft x...
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
(4) 3 PLUG VALVES (A52472)
(4) 3 PLUG VALVES...
