Good morning!!!!
   / Good morning!!!! #189,161
Good Morning Again,
VA lot is 7.3 acres, half gentle sloping grass. Neither lots have your views.
Having a view is nice but here where there is a view there is also wind. A cold wind in the winter and hot wind in the summer, too much wind drives me nuts. o_O
Dennis, Scootr is right about the wind ! I love the views but I have been here in the winter when the whole house actually shakes from that wind out of the west !
Also in the summer, being up at 1200 ft we get baked by the sun until it goes down behind the mountains ! So plus and minus to both I guess ! 😉
Also up here I built the barn and never even needed a building permit ! That may have changed since then !
   / Good morning!!!! #189,162
Good Afternoon,
A couple start and finish pics of our mulch work today !
Loaded 10 bags in the loader, the tractor took it better than my F150 !
The AG tires on the tractor really marked up the lawn in front of the wall and flower bed ! Tractor and loader weigh well over 5000 lbs and that’s not counting the counter weight on the 3 pt hitch ! Hopefully they will pop back up again ! 😒
   / Good morning!!!! #189,163
59F and cloudy @ 10:45, calling for a high of around 63F for the day.
My eyelids were so heavy last night, I couldn't hold them open past 22:00 ...
Slept good though ... (y)
Coffee tasting very good ... even though it's just the last of yesterday's warmed up ... ;)
Got 36 cells planted with Detroit Dark Red sugar beet seeds first thing early yesterday morn ...
Then got all the seed trays watered that needed it.
Moved the sprouted Redbud seedlings outside onto the grill. By the end of the day they were looking like they had enjoyed it.
Then moved aquarium planter outside along with the 4 square pots that go in it. Need to shim up one end of that to level it out.
Got the new greenhouse moved in front of the sliding glass door in the dining room where the aquarium planter stand had been.
Moved the 2 seed trays with the peppers and tomatoes in them into the new greenhouse, put peppers on the top shelf where they would get the heat. Evidently they liked that as this morning a bunch more seeds had popped.
Somewhat repaired the pallet the Menards order was on, still have to replace one board.
Refilled hopper feeder + scattered some for the ground feeders. Still need to reset the pole for the tube feeders.
Created more potting mix using screened compost + perlite + vermiculite.
Started making a screen for the tow-behind spreader out of 1/2 hardware cloth. Got it cut to size and started forming to fit, still have some to do to finish it up.
Got a load of long branches and sapling trimmings hauled up to the brush pile in the compost wood lot.
Snagged one of the cedar "posts" on the way back and brought it down to the house and put it on the tall saw horses. The log is just under 13' long.
Tested out the new draw knife on that ... worked very good ... (y)
Outside layers of the cedar log was pretty punky, an inch or so deep ... but the heartwood below that seemed solid.
Today might be the day to go to town on that, as it cloudy and the temps are cooler.
Took Cub up and got all the leaves and dead weeds raked off the screened compost pile. Did not spray that as it was a little too windy at the time I was up there. Grabbed the short steel sawhorses on my way back down.
Loaded large stepladder onto pallet forks along with four sections of 3/4 copper pipe and hauled all that around back with the Kubota. Got copper pipe stowed in the basement.
Used a couple of 2 x 4's to brace up the end of the deck where the support post had gotten bumped with the loader and had broken. Then broke off the support post and pulled it down.
Set up stepladder and pulled the nails out of the first joist with the crowbar, they came out pretty easily (end-nailed)
The other end is toe-nailed so once I swing that first joist over enough to clear the ledger board it rests on I should be able to pull it down.
But first I have to remove the decking that is nailed into it.
Woman worked on cleaning up back patio area while I was doing that.
Got all the seed heads cut off the rhubarb.
Got the 3 new t-posts for the last section of the vertical trellis pounded in with the new post pounder.
Man ... that thing worked slick ... and it was on sale !
Executive discussion and planning session while we were resting during that about relocating the rhubarb and where to place raised beds in the garden. Also some discussion on fencing.
Rhubarb can be relocated outside of fenced area since animals won't eat it (the leaves are poisonous)
Also determined flower beds don't need fenced - the deer and other critters aren't interested in the iris, daffodils, or peonies. They do nip off the tops of the day lilies when they first come up ... but tend to leave them alone after other browse becomes available.
After that was done Woman went back to patio clean up and I started spraying additional areas in the garden with glyphosate.
About the time I was finished with that the sun was getting low in the western sky, Woman had had enough and needed to go check the spaghetti sauce She started earlier.
So we gathered up all the tools and I headed around to the front and dropped the dump cart and then went out and re-mowed some of the front for about 20 minutes while She cooked the spaghetti noodles.
After dinner I ran the Cub over to the barn and got it put away as it was supposed to rain overnight, Woman went over and gave enioghbor lady's cat its nightly feeding.
Agenda for today:
Maybe work some trimming up and skinning that cedar post, although it's gotten darker and the temp has already fallen to 53F.
Maybe a trip up to the Menards in Cuyahoga Falls for those wire remesh panels.
There is a small planting bed at the southeast corner of the house that I want to remove. The PT timbers that make up the walls are rotten and I want to get it out of the way so I can get the Kubota up close to the deck in order to chuck the junk deck boards into the loader bucket for disposal.
But first I need to dig up and relocate a Stella D'Oro's and several hosta. We have a new planting bed/circle around a small oak on the west side that I covered with chopped up leaves last fall, at least some of the hosta can go there. Stella will probably get potted for the time being.
Amazon orders due in today, peppermint extract is on the truck and out for delivery, also new gardening tool for Woman not yet shipped ... but due in by 22:00.
Hope everyone is having a decent Friday ... (y)
   / Good morning!!!! #189,166
Good Morning! Bright sunshine and 72F with light breezes. The Chamber of Commerce's prayers were answered.
Looks like everyone is in a good mood for Friday and the weekend. I always say TGIF - only two more days to Monday. :ROFLMAO: I love weekends but everyday is Saturday now.
Enjoy the day and have fun, eat some ice cream and not the sugar free kind.
Prayers for our Nation!
   / Good morning!!!! #189,167
I get tired just reading your postings of activity @rswyan. I think you have a mastery of time.
LOL ... good one ... (y)
I'll be sure to share it with The Woman.
She is probably going to want to have a word ...
:LOL:
   / Good morning!!!! #189,168
Got mower off the trailer this morning, had already rained some.
Had our weekly breakfast with 3/4 of the usual gang today, since we have an event tomorrow.
Costco run after getting home with the wife. My son drove in. He still complains of leg pain.
   / Good morning!!!! #189,173
53F and clear @ 20:30, heading down to around 44F for the overnight low.
Sun came out so I got a little more work done on skinning that cedar log before I headed down to Menards:
Widest diameter dimension at the base is around 13", so I'll need to trim it down quite a bit to get it to fit into a 12" posthole.
Really need to move it over to the lower sawhorses for further work.
Got the wire remesh picked up, mulch was on sale so I went ahead and placed an order for another 30 bags before I left and grabbed that while I was there as well.
When I got home Woman had gone to the grocery to do a market and pick up some items, so I went ahead and reheated the spaghetti from yesterday. This time I remembered to add some crushed red pepper which made a world of difference ... (y)
Main Redbud now fully in bloom and looking good:
Plans for this evening:
1. Water plants.
2. Install 2' LED lights in greenhouse.
3. Maybe repot the tomatoes that survived.
4. Possibly watch a movie on Prime.
Hope everyone had a great day ... (y)
   / Good morning!!!! #189,174
Good Evening Dennis,
Congrats on your decision! Do you have any Gingseng on the WVA property ?
I can come down and dig it for you ! 😉
Just kidding, the best of luck with your decision !! 🙏
   / Good morning!!!! #189,175
Good (Saturday) morning. Overnight Low of 3.8C and it's presently 21.1C, clear & calm.
Good Church/Parish meeting last evening which concluded at the appointed time.
I've made an 'executive decision' that I won't be attending this year's AGFEST... after 10 straight years I've come to the conclusion that there really isn't anything that I 'need'. (happy wallet!) Oh, sure, there are some 'dream implements' that I would love to have but those will have to wait until my lottery numbers come good. 😁
The only thing going on today is, yet another, meeting this evening. Hopefully I'll be home by 2130.
   / Good morning!!!! #189,176
We only looked from the driveway and road. I was looking for pink marking tape, and copperheads. NW corner looking east.
SE corner looking north. Fairly flat down in this corner.
Property goes to center of the roads on 2 sides.
   / Good morning!!!! #189,177
Good Morning
46° and partly cloudy, supposed to warm up a bit, but won’t see 60.
Yesterday started with my daily dose of Fusion 360, then went and picked up a friend from the auto shop and took him home. About a 30 mile trip all together, the Prius had enough charge to not burn any gas.
Went out to lunch with the wife, puttered around in the shop, collected all the trash and recycling, and got it all to the street.
I tried some 20 ga (.035) steel on the plasma table to see how it would cut. Combined that with a Fusion exercise to convert a normal font to a stencil type to cut it out.
Came out pretty well considering how fine some of the cuts were.
Not sure what today’s adventures will be, good chance that we will play music tonight, but not confirmed yet. Other than that, I’ll roll with whatever pops up.
Popgadget, those cuts look great, especially the thin areas. Our machine is blowing out the "thin" areas right now. My student worker and I were doing the same thing today. But we were not getting cuts as smooth as you. Found out our X and Y won't feed higher than 175 inches/minute. We are cutting 14 gage .072" thick mild steel, 45 amp, hypertherm "fine cut" tip, 80psi, .060" height, 80ish volts, .049" kerf. Table says to feed at 270 ipm. Our table has stepper type motors and are limited by the factory to 175 I guess. The manual states that the plasma flame is "hungry" for metal, and will overcut if under fed on thinner stocks. So we are getting too much dross. Our old timer who's been there a number of years, said "Told ya, should've gotten 1/4" thick material to feed it slower."
Hope he continues to heal, day by day.
Coworker's wife is having a baby any day now. He'll take off work to help her out for a while. Happy for them.
Prayers for our team.
   / Good morning!!!! #189,178
RNG - I don't believe that there is any kind of escrow service with Market Place, and yes, my experience is mostly via Facebook for that.
it's direct between seller and buyer, and there are a lot of scams, shady practises that you need to be aware of. I typically STAY LOCAL, go see what I'm interested in, negotiate as desired, and hope for the best. I always think twice about deposits, but that is sometimes the only way to "hold" it at most sellers got FCFS in the sense of Arrival anf Pick-Up; rather than Contact and Interest. Sometimes I'm 3-4 hours away, so others tend to get there first.
Good Descriptions, MULTIPLE Photos, and Seller RATINGS are helpful.
Single photos tend to be suspicious to me, as those are easy to copy and paste. I've seen the same singular photo, a too good to be true ad, and basic info, listed by the same seller in 8 different provinces, indicating a local listing ... that is certainly a scam. And I tend to call them out - then they vanish, and re-appear later.
   / Good morning!!!! #189,179
Coffee has been poured. 38° with clear skies this morning. Heading to 47° with partly cloudy skies. Yesterdays rain total was .34" Did not do much yesterday. All the exercise and projects I have been done lately has caught up with me. Left foots hurts when walking. Giving a few days of rest to see if it gets better. I see the to do list getting longer.
Full April Pink Moon will happen next Tuesday at 7:49pm EDT. Its Pink name comes from a pink flower that blooms this time of year.
Everyone stay well and safe.
Good Morning All.
   / Good morning!!!! #189,180
Good morning, the low is 34 and the high to 41°F. Wind WSW 11 mph. 40% chance of showers.
Yesterday and the day before it stopped raining about 2 or 3 P.M., about the time we usually stop working for the day. :( (Nothing got done on the tank install).
Today IF it doesn't rain until later there WILL be something done on the install. At minimum get the hose reel up. Then it will be just the tank, pump and gauge/whistle to go.
Scaredychicken, back when I was boat shopping, there was a woman in Montreal that wanted to sell me a 50' Trojan for 10 grand. She was going to pay the freight out of the 10 Gs. I told her I wanted the exact location of the boat so I could sent a surveyor to look it over. She said she would supply the surveyor.
This was all done by email, so I took it all to the OPP (Ontario Provincial Police) and let them look it over. They told me that if it sounds too good to be true, it probably is a scam. I sure am glad I didn't bite.
I only buy in person, now.
Have a safe day all
2008 CAT D6T DOZER (A58214)
2008 CAT D6T DOZER...
2022 Ram 2500 (A55973)
2016 Chevy Silverado Z71 4wd 5.3L V8 (A56438)
2016 Chevy...
2017 CATERPILLAR 289D SKID STEER (A60429)
2017 CATERPILLAR...
30ft Highway Trailer Co. Lowboy (A56438)
30ft Highway...
2004 Ford F-450 4x4 Venturo ET18KX 2 Ton Crane Service Truck (A59230)
2004 Ford F-450...
