Float Switch 3430
/ Float Switch 3430 #1
Diamond P
Wilmington DE.
Kubota 3430
Bought a 2003 Kubota 3430 and i'm looking for the float switch for the fel. Not sure if even has one?? Thanks
/ Float Switch 3430 #2
Move the fel control firmly to the right like you u we're going to dump the bucket.
/ Float Switch 3430 #3
I've never seen float on the dump circuit, pretty sure Sandy is wrong. Float, if it's there, is always on the lift circuit. Push the stick all the way forward & there should be a detent there for float. Assuming the 30 series is like every other Kubota I've ever driven.
/ Float Switch 3430 #4
I had a 5030 and the float is the same as 5740, forward past the detent.
/ Float Switch 3430 #5
Sorry about that. You're right I should have said push forward beyond the detent. I guess I need a nap!
/ Float Switch 3430
Thanks, I'll try pushing the stick all the way forward.
/ Float Switch 3430 #7
I had a 2004 L3430HST and the joystick float position is all the way forward past the detent as Fallon suggests. No float on the dump.
2007 PETERBILT 379 6X4 T/A SLEEPER TRUCK TRACTOR (A59911)
2007 PETERBILT 379...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A61307)
2-Row Peanut...
2023 John Deere 317G Compact Track Loader Skid Steer (A61572)
2023 John Deere...
2006 Honda Odyssey Van (A61574)
2006 Honda Odyssey...
2019 Ford F450 Extra Cab 4x4 Service Crane (A62613)
2019 Ford F450...
2006 Mack CV713 Flatbed Truck (A62679)
2006 Mack CV713...
