Float Switch 3430
/ Float Switch 3430 #1
Diamond P
Wilmington DE.
Kubota 3430
Bought a 2003 Kubota 3430 and i'm looking for the float switch for the fel. Not sure if even has one?? Thanks
/ Float Switch 3430 #2
Move the fel control firmly to the right like you u we're going to dump the bucket.
/ Float Switch 3430 #3
I've never seen float on the dump circuit, pretty sure Sandy is wrong. Float, if it's there, is always on the lift circuit. Push the stick all the way forward & there should be a detent there for float. Assuming the 30 series is like every other Kubota I've ever driven.
/ Float Switch 3430 #4
I had a 5030 and the float is the same as 5740, forward past the detent.
/ Float Switch 3430 #5
Sorry about that. You're right I should have said push forward beyond the detent. I guess I need a nap!
/ Float Switch 3430
Thanks, I'll try pushing the stick all the way forward.
/ Float Switch 3430 #7
I had a 2004 L3430HST and the joystick float position is all the way forward past the detent as Fallon suggests. No float on the dump.
