Float Switch 3430
/ Float Switch 3430 #1
Diamond P
Wilmington DE.
Kubota 3430
Bought a 2003 Kubota 3430 and i'm looking for the float switch for the fel. Not sure if even has one?? Thanks
/ Float Switch 3430 #2
Move the fel control firmly to the right like you u we're going to dump the bucket.
/ Float Switch 3430 #3
I've never seen float on the dump circuit, pretty sure Sandy is wrong. Float, if it's there, is always on the lift circuit. Push the stick all the way forward & there should be a detent there for float. Assuming the 30 series is like every other Kubota I've ever driven.
/ Float Switch 3430 #4
I had a 5030 and the float is the same as 5740, forward past the detent.
/ Float Switch 3430 #5
Sorry about that. You're right I should have said push forward beyond the detent. I guess I need a nap!
/ Float Switch 3430
Thanks, I'll try pushing the stick all the way forward.
/ Float Switch 3430 #7
I had a 2004 L3430HST and the joystick float position is all the way forward past the detent as Fallon suggests. No float on the dump.
LMC Nitrogen Applicator (A62177)
LMC Nitrogen...
2015 Mack Granite GU713  Tri-Axle Dump (A62613)
2015 Mack Granite...
2021 Frontier GM4060E Mower (A64047)
2021 Frontier...
2020 John Deere HPX615E Gator 4x4 Diesel Utility Cart (A61572)
2020 John Deere...
2012 International Prostar (A63118)
2012 International...
2011 John Deere 5085 70HP Utility Tractor (A60352)
2011 John Deere...
