Float Switch 3430
/ Float Switch 3430 #1
Diamond P
Wilmington DE.
Kubota 3430
Bought a 2003 Kubota 3430 and i'm looking for the float switch for the fel. Not sure if even has one?? Thanks
/ Float Switch 3430 #2
Move the fel control firmly to the right like you u we're going to dump the bucket.
/ Float Switch 3430 #3
I've never seen float on the dump circuit, pretty sure Sandy is wrong. Float, if it's there, is always on the lift circuit. Push the stick all the way forward & there should be a detent there for float. Assuming the 30 series is like every other Kubota I've ever driven.
/ Float Switch 3430 #4
I had a 5030 and the float is the same as 5740, forward past the detent.
/ Float Switch 3430 #5
Sorry about that. You're right I should have said push forward beyond the detent. I guess I need a nap!
/ Float Switch 3430
Thanks, I'll try pushing the stick all the way forward.
/ Float Switch 3430 #7
I had a 2004 L3430HST and the joystick float position is all the way forward past the detent as Fallon suggests. No float on the dump.
2014 International WorkStar 7300 4x4 Altec AA55E 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A61567)
2016 Ford F-150...
2005 Ford F150 Lariat 4x4 Crew Cab (A62613)
2005 Ford F150...
2025 IRANCH IRLMB Mixing Bucket Mini Skid Steer Attachment (A61572)
2025 IRANCH IRLMB...
2001 International 4700 Dump Truck (A64047)
2001 International...
2006 Mack Granite CV713 Dumping Flatbed (A62679)
2006 Mack Granite...
