first time painting - should I grind off the thin surface rust or just apply rust converter?
   / first time painting - should I grind off the thin surface rust or just apply rust converter? #51
I am not sure why you would WANT to paint over something that could be scuffed off so easy? There is nothing wwrong with that product and in some cases it could be a big labor saver. I can see wiping it in cracks and corners, auto work mostly which it was born of I believe. Contrary to some popular belief its not new.
On steel its not all rust but mill scale. The early suggestions about wire wheels are ok too, you can actually remove scale if its done hard enough.
If I want it to look good I sand it, if I want it super I sand, sandblast to remove any grinding marks, can go to white blast if you want but then sane or pad scuff, blow off and paint.
   / first time painting - should I grind off the thin surface rust or just apply rust converter? #52
Want smooth sand, prime, sand prime and paint. The sand or scuff flattens the tops off any peaks managed to poke thru it. Gives another chance to level the surface.
   / first time painting - should I grind off the thin surface rust or just apply rust converter? #53
I've never even seen or heard of that stuff - I'll look for it now
Egon explains it well!
It is not just the rust you can see that is the problem!
   / first time painting - should I grind off the thin surface rust or just apply rust converter? #54
   / first time painting - should I grind off the thin surface rust or just apply rust converter? #55
Where did he explain anything? Clucking on a link about some exotic alloy is different than explaining something..
Secondly just how is this "the problem"?
   / first time painting - should I grind off the thin surface rust or just apply rust converter? #56
I bet we put him under oath we find out he didnt even read it, was the first thing come up on Google.
   / first time painting - should I grind off the thin surface rust or just apply rust converter? #57
It work I've been using this Por 15 stuff, costly but does seems to work. I do wire brush everything in advance and no primer. Anyone else using it?
   / first time painting - should I grind off the thin surface rust or just apply rust converter? #58
Paint a lot like welding, dont need to know everything about it to do a good job, most of it is simple work, the difference between those take a couple minutes and those with fugg it attitude. Its really not that complicated and shouldnt be.
If your welding at a location that takes pictures you’ll need certification.
   / first time painting - should I grind off the thin surface rust or just apply rust converter? #59
Where do you come up with them?
   / first time painting - should I grind off the thin surface rust or just apply rust converter? #60
Show us somewhere this is written?
Spreader Attachment (A56859)
Spreader...
EZ-GO Electric Golf Cart (A60462)
EZ-GO Electric...
Vermeer 605 XL Round Baler (A59814)
Vermeer 605 XL...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
1992 Norris Long Basket Trailer (A60460)
1992 Norris Long...
Enclosed Service Truck (A55788)
Enclosed Service...
