first time painting - should I grind off the thin surface rust or just apply rust converter?
   / first time painting - should I grind off the thin surface rust or just apply rust converter? #11
None of that crap, scuff or sand the loose off, scuff again with maroon Scotchbrite, blow off and paint.
   / first time painting - should I grind off the thin surface rust or just apply rust converter? #12
Even with phosphoric acid (Ospho) you should hit it with a wire brush to get the loose stuff off.
I don't usually bother with primer after the acid dries.
   / first time painting - should I grind off the thin surface rust or just apply rust converter? #13
OSPHO is amazingly effective at creating a bite surface for the primer/paint.
You should try it some time!
   / first time painting - should I grind off the thin surface rust or just apply rust converter? #14
It probably is good. I just dont use it, dont use any prep except mechanical.
   / first time painting - should I grind off the thin surface rust or just apply rust converter? #15
After wire wheel or whatever mechanical cleaning, I like to clean the dust off with air hose. If that's not availbe I use paint thinner/acetone mix. Use rubber gloves with that stuff, it cuts everything..
   / first time painting - should I grind off the thin surface rust or just apply rust converter? #16
Then you are leaving rust behind on the metal that will just keep on rusting.
   / first time painting - should I grind off the thin surface rust or just apply rust converter? #17
I wonder how it is all my stuff isnt rusting thru? What makes it rust?
   / first time painting - should I grind off the thin surface rust or just apply rust converter? #18
A lot of industrial primer is rated for tightly adhered rust.
   / first time painting - should I grind off the thin surface rust or just apply rust converter? #19
Ospho is good stuff. Beware though; make sure you have old clothes on. Ospho is like water and it is easy you splash it on good clothes and in a few months you will start seeing white sploches all over them.
Thanks for all the good and helpful replies. I didn't mention in my queston (I didn't know it matters at the time) that half of the implement is hardox steel that comes with a primer already on it with only small scratches.. Some not so small areas of S355 steel are also rust free. The pipe was the only problematic part. Phosphoric acid based rust converters are therefore out of the question for half of the machine. I went with this product instead: Rust Converter
This document contains the ingredients: https://www.weicon.de/media/pdf/2a/30/c5/MSDS_111550_EN_EN_.pdf
Never used it before and have no idea how it well it works.
ADS Bulk Seed Buggy (A59814)
ADS Bulk Seed...
2018 John Deere TX (A53317)
2018 John Deere TX...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
2025 Nationcraft 8.5X36TTA3 38ft Tri-Axle Enclosed Trailer (A59231)
2025 Nationcraft...
ALLMETAL MOBILE PRESSURE WASHER (A58214)
ALLMETAL MOBILE...
2016 INTERNATIONAL PROSTAR TANDEM AXLE DAY CAB (A59904)
2016 INTERNATIONAL...
