Snow Equipment Owning/Operating First snow!!!
/ First snow!!! #1
LAXPatrick
God\'s Country, WI
John Deere 4310
Got a few inches of the white stuff last night so I got my first opportunity to try out the 4310! Have a 430 FEL and a 6' Frontier rear blade.
300 feet or so of gravel, 150 feet of grass/path down to the pole building and a 3 car width pad in front of the garage.
First off - in 4WD this thing just keeps on going!
Techniques - I turned the blade around and angled it off - it's only like 10 degrees, would probably be more efficient if I could get more angle. Overall, this blade drag technique worked well on my driveway - no damage to the gravel and it moved the majority of the snow off. It'd be nice to get down farther, but that'd likely be at the expense of the driveway. I haven't figured out the optimum location/technique for the blade drag castings at either end of my loop yet...
I tried using the FEL on float - found that it dug in too much on uneven ground (have to patch those when this stuff thaws!). I used the drop and drag technique to drag the snow from in front of the garage - worked fairly well, but I think I need a steeper angle to get all the way down to the snow...
I've read some of the posts on this topic - any other techniques folks use with good results and similar equipment?
Almost forgot - haven't used the iMatch much until this morning... I put it on the tractor in hopes that it'd just pop on. It did! My rear blade was outside the barn in the snow - backed up to it, lifted up, slapped down the levers and I was off! Never got off the seat. Now if I could just find the time to get it rigged for my Frontier RFM that it doesn't fit (read BeenThere's posts, not sure if I totally have that figured out to the point of confidence but I've got a few months to noodle on that one...)
LAXPatrick
/ First snow!!! #2
Normally we begin to build a frozen base by driving over the first snowfall and letting it pack between the gravel. Once you have done that and you get additional freezing temps it will build a hard frozen base. From that point forward clearing the drive will be simpler and you won't move the gravel around in the process. Think snow! /forums/images/graemlins/grin.gif
/ First snow!!! #3
Hey Pat,
Was in the big town of LAX yesterday, headed out up the big hill and hit the snow. From Roch here and I think you guys got hit harder.
murph
/ First snow!!! #4
</font><font color="blue" class="small">( It'd be nice to get down farther, but that'd likely be at the expense of the driveway.)</font>
Hi LAX,
I think I got this idea (see attachment) from someone else on this board, but I had this post welded on last year. It allows me to put a/several weights on it and really helps prevent my blade from riding up over the snow.
Good luck and keep having fun. They're calling for 6-12" of snow here by tomorrow afternoon!
/ First snow!!!
Cool idea - may have to try it if I have trouble "gettin' down"...
Day 2 - more snow and some drifts. This is too easy. Shovels are for people who don't have tractors...
Turned the blade around and scraped the concrete pad - worked just great. Didn't use the FEL at all this morning, just a couple of passes with the blade.
I imagine that with a "real snow" things get a lot more interesting, take more time, and require some more serious FEL work.
Good times!
Yeah even town (10 miles away) didn't get much snow. We're always 2-3 degrees cooler. They only had a dusting of snow and we're under 4 inches or so.
Spent last night hooking up the horses' heated water buckets and the tank heater. Looks like we should thaw out on Friday. That'll be a good opportunity to put some driveway markers out.
I've also got an excavator coming in to dig a trench (no backhoe on my 4310) for getting power and water down to the barn. He's assured me that he'll be able to get it done... Running 12GA extension cords down there makes me nervous with the tank heater (1250 watts) and 3 bucket heaters (125 watts x 3) along with a few flourescent lights over the stalls...
LAXPatrick
/ First snow!!! #6
A contractor person who I had done business with several times had some heavy duty extension cords run in the snow and he went to pick one up and got hit real hard with the electricity.I went to see him a few days after and he didn't even recognize me, it really messed up his mind, and the last I knew he never recovered fully from it and this happened several years ago.Be very careful until you get things underground.
/ First snow!!! #8
LAXPatrick,
If you curl your bucket up a bit while in float, it will keep the edge from digging in. You won't get down to bare ground/asphalt, but in a deep snow you can make it driveable with a car and keep from digging in.
Tim
/ First snow!!! #9
</font><font color="blue" class="small">( I imagine that with a "real snow" things get a lot more interesting, take more time, and require some more serious FEL work. )</font>
That's why they make snowblowers /forums/images/graemlins/laugh.gif Not sure if I would call it more interesting or just plain amazing. Doesn't really matter how deep it gets, one pass and you're done. If I plan to use the blade for a storm, I try to get out every 6" or so with my TC24. With the blower I just wait till the storm is done.
We might be getting some snow this week!
Brad
/ First snow!!! #10
Once upon a time, in a land far, far away....
I was using a 4WD CUT with 6-foot rear blade to remove a very heavy snowfall (for the central NC area) of about 6" depth. This was a heavy and wet snowfall, the day was bright but bitter winds were blowing. Things were going well but taking longer than expected and I started getting cold. To save time, I lowered the FEL bucket thinking I could push AND pull snow at the same time.
Stupid me!
As I was watching the FEL bucket closely, the rear blade gathered up so much snow that it cascaded under the rear axle and actually lifted the tractor off the ground /forums/images/graemlins/shocked.gif
Now I've got snow jam-packed under the FEL subframe, three f00t high pile of it between the rear wheels and the blade and remember the FEL? It's got a VW size pile in front of the bucket.
It took me the rest of the day to dig it out with a shovel /forums/images/graemlins/tongue.gif and the <font color="red"> </font> really <font color="black"> </font> bad part is my wife noticed and kept asking why I wasn't using the tractor. /forums/images/graemlins/blush.gif
Good thing we don't get much of that snow stuff. Us Southern Boys just can't handle it.
/ First snow!!! #11
44trx..
Look familiar /forums/images/graemlins/grin.gif. Can't remember who mentioned it first but I read it too.
LAX,
But, where are the PIC.'s??? We were promised 3-10" and got squat! All rigged up and no snow to blow /forums/images/graemlins/frown.gif.
/ First snow!!! #12
Funny /forums/images/graemlins/grin.gif Your adding weight to the back blade and I'd prefer mine was lighter. It likes my undulating asphalt, even with the shoes. We are always adjusting our implements to suit. Gettin dialed in.....Half the fun. /forums/images/graemlins/smile.gif
/ First snow!!! #13
</font><font color="blue" class="small">( Funny Your adding weight to the back blade and I'd prefer mine was lighter.)</font>
For the most part, I love my sub-cut GC2300. But I think the implements for these machines generally tend to run toward the lighter side. On dry-moderate snow, my backblade will keep pretty good contact with the ground, but in wetter, packable snows, it tends to ride up over the snow. The weights really help the blade to maintain ground contact.
/ First snow!!! #14
<font color="blue"> (Once upon a time, in a land far, far away....) </font>
Great narrative. I laughed so hard when I read your story. I could just see myself doing the same thing.
It made for great Thanksgiving dinner conversation too. Thanks for being willing to share.
/ First snow!!! #15
Well, it's finally happening...We're getting snow. There's a good two inches right now and it's still coming down hard. I wanted so bad to hook up the box blade tonight in the dark and start moving white stuff, but I stayed inside with my wife and kids instead and hung lights on the Christmas tree.
Tomorrow morning at the crack of dawn, though...I'll be out there. This will be my first chance to move snow with a tractor. Expect pictures of my little tractor when it gets stuck.
/ First snow!!! #16
Chris,
Actually, I generally don't use the extra weight for the RB for snow. The medium blade and the front end blower seem to be a pretty good balance. The weights are for counter balance to heavy loads in the FEL (generally dirt, gravel, overload...). The 1st storm we got here was 10" of very wet snow, dropping the utility power for about 20 hr.s. I hadn't put the blower on yet (and am not sure I wanted as the ground hadn't even begun to freeze). So, I cut my way out of a bunch of downed trees in 600' drive, dropped the BH, picked up the RB and bucketed and bladed the snow. The extra weight worked pretty well with the bucket pushing and then lifting the wet snow. The extra weight also seemed to slow down the lift of the RB, a little, as I tried to feather above the gravel and mud surface...maybe just my imagination (it gets active with enough seat time /forums/images/graemlins/smirk.gif). Ofcourse, I could have just dialed back the adjuster another little bit but what fun would that have been?
Tom
2022 MAXEY MAXX-D 40’ GOOSENECK EQUIPMENT TRAILER (A59914)
2022 MAXEY MAXX-D...
New, Landhonor Skid Steer Pallet Forks  (A62679)
New, Landhonor...
2014 Lincoln MKS Sedan (A64557)
2014 Lincoln MKS...
Lonestar Panel (4) 24ft. Free Standing Panels (A65640)
Lonestar Panel (4)...
New/Unused Wolverine Hydraulic Screening Bucket (A65583)
New/Unused...
Salt Dog by Buyers Slide in Spreader Box 10' (A62679)
Salt Dog by Buyers...
