Electrical Service Question /Concern
/ Electrical Service Question /Concern #21
To Lookingfornew.............I helped my daughter build a house just off HWy 11 just a stones throw south of the MTO weigh scales between Callender and Powassen. (So just north of you I imagine) They had a nightmare dealing with Ontario Hydro with them charging ridiculous for pole installation and even my daughter having to pay to replace the pole on the rural road (not on their property) and then had service read billing charges always wrong for the first year, yep HYDRO company , Ontario's biggest boonddoggle yet.
And the premier is selling it off. :(
Hydro makes Ontario a bundle of money every year, maybe that is why she is selling it?
I pass the Wasi scale every time I go to North Bay. Wasi scale is the official name for it. Most of us just call it the N.Bay chicken coup.
/ Electrical Service Question /Concern #22
It most definitely is not related to the primary feed to the transformer.
I'm curious why it couldn't be primary feed. Granted, I don't know how you crazy Canadians do things, (politely I'm guessing :D) but couldn't the transformer be like this:
...assuming transformer is center grounded, if you lost one leg of the primary wouldn't you only have one leg of the secondary?
I guess OP could always ask his neighbors if they experienced same thing.
I agree it's more likely to be a secondary problem.
Edit: Ok, I guess it's unlikely the primary would be center grounded (wye), so yes, with a delta primary you would lose both secondary legs if one primary goes out. ...but if it was....
/ Electrical Service Question /Concern #23
Oh yes, Powassan the Capital of North Bay. Then there is Sundridge which used to be the best little town by a d@m site.
The closest I get now is taking the 400 around to 17 if I miss the ferry to South Baymouth.
There is what the public sees and hears about Ontario Hydro, hydro one and Ontario Power Generation. You should observe the disaster from the inside started by Harris and made much worse by Dalton and Wynne.
/ Electrical Service Question /Concern #24
It's single phase on both the primary and secondary .
If neutral current is supposed to flow on the neutral conductor . The ground system is to only hold grounded components to near earth potential. If there is current flowing in the ground system there is something very wrong.
/ Electrical Service Question /Concern #25
Sundridge is called 'sunny'.
Best little town by a d@m site is Latchford.
I am 5 miles north of Sunny Sundridge, out in the boonies.
/ Electrical Service Question /Concern #27
Alright I was close . Last time I was through Latchford was either 1998 or 2003 iirc.
I wasn't correcting to be spiteful, but just to clarify for you.
I was through there 4 weeks ago. The old dam is getting rebuilt. They've been at it all summer and I don't expect they will have it done by next summer.
Of note : Coby's picture is the same type of transformer everyone on my street has, so we each have one delegated to us and I saw at least two wires coming out of the drum to the wires above. So us Canadians do do it the same smile!! Although the nuts and bolts on it are probably metric :)
/ Electrical Service Question /Concern #29
Another possibility,perhaps: if the lights that when off, could they have seriously dimmed? Low voltage could make a tungsten bulb appear to go out while still having enough voltage to make a regulated supply in a tv and sat receiver function ...with capacitor storage etc. Think back to which bulbs and how long. My $.02
Rob
/ Electrical Service Question /Concern #30
I wasn't intending on being huffy or insulted . I appoligize if I appeared as such.
/ Electrical Service Question /Concern #31
Short answer is the primary winding on a single phase transformer is never center grounded because it isn't needed to obtain 120/240 V on the secondary and it would add a level of cost and complexity that serves no purpose.
On any single phase distribution transformer I've ever seen the primary winding was always connected in either one of two ways...either phase to phase like this
or phase to ground like this
If it only has a single primary bushing the H2 end of the primary winding will be connected to the case (usually internally) which is connected to ground, if your system uses a single primary feed and an earth return to complete the circuit or a grounded conductor in areas where the earth's conductivity is too poor for an earth return system but that's besides the point of your question.
New/Unused Wolverine 84in Dozer Blade/Snow Pusher (A65583)
New/Unused...
1980 Gleaner F2 with heads (A61307)
1980 Gleaner F2...
Landhonor 24" Semi-Automatic Tire Changer (A62679)
Landhonor 24"...
2007 PETERBILT 340 ROLL OFF TRUCK (A59909)
2007 PETERBILT 340...
2016 Ford Escape SUV (A61574)
2016 Ford Escape...
SHORTWOOD 6 BOLSTER LOG TRAILER (A64276)
SHORTWOOD 6...
