Educate me on zero turns
/ Educate me on zero turns #22
Except I have UTV's too. Gas.:)
True. Fortunately I can drive my UTV to a nearby gas station.
I believe Kubota sells diesel UTV's.
/ Educate me on zero turns #23
We switched from a gas Kawasaki Mule to a diesel Kubota RTV-X. Now the 3 tractors, the ZD1211 ZTR, and the RTV-X are all diesels. They get refilled from a 58-gallon John Dow fuel pod on a small trailer. The chainsaws, blowers, the weed eater, and the pole saw are all battery powered. The only gas motor left is a small 50CC Honda on the pasture vacuum. A gallon of gas goes a long way.
/ Educate me on zero turns #24
Are you using the electric chainsaw to cut firewood? or is it just for cleaning up after storms?
I can see a battery power being good to have in the UTV when driving around the trails of a property. Certainly for a lot of stop/start cutting. The perils of a gas powered saw is always starting them. It's even worse with todays saws, if they don't get run long enough for a second hot start. My Husky 550 is great on a cold start and a hot start. When it's only run a few minutes and then I try to restart is usually where the issue is.
(15) Polyethylene Road Bed Protection Pads (A60462)
(15) Polyethylene...
2007 International 4300 Bucket Truck 55' (A62613)
2007 International...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
2000 Yale GLC030A 2,500lb Propane Foklift (A61572)
2000 Yale GLC030A...
429872 (A61166)
429872 (A61166)
2021 Harley-Davidson FLHP Road King Motorcycle (A61574)
2021...
