Educate me on zero turns
/ Educate me on zero turns #22
Except I have UTV's too. Gas.:)
True. Fortunately I can drive my UTV to a nearby gas station.
I believe Kubota sells diesel UTV's.
/ Educate me on zero turns #23
We switched from a gas Kawasaki Mule to a diesel Kubota RTV-X. Now the 3 tractors, the ZD1211 ZTR, and the RTV-X are all diesels. They get refilled from a 58-gallon John Dow fuel pod on a small trailer. The chainsaws, blowers, the weed eater, and the pole saw are all battery powered. The only gas motor left is a small 50CC Honda on the pasture vacuum. A gallon of gas goes a long way.
/ Educate me on zero turns #24
Are you using the electric chainsaw to cut firewood? or is it just for cleaning up after storms?
I can see a battery power being good to have in the UTV when driving around the trails of a property. Certainly for a lot of stop/start cutting. The perils of a gas powered saw is always starting them. It's even worse with todays saws, if they don't get run long enough for a second hot start. My Husky 550 is great on a cold start and a hot start. When it's only run a few minutes and then I try to restart is usually where the issue is.
2018 Ford F-750 IMT 6025 7 Ton Crane Mechanics Truck (A64194)
2018 Ford F-750...
Linx UT357714T 14ft Trailer (A65640)
Linx UT357714T...
2012 Ford E-350 16ft. Box Truck (A64556)
2012 Ford E-350...
case 370 glass door never installed (A61307)
case 370 glass...
2019 KUBOTA KX057-4 EXCAVATOR (A62129)
2019 KUBOTA...
2004 International 4400 Single Axle Dump (A62613)
2004 International...
