Educate me on zero turns
/ Educate me on zero turns #22
Except I have UTV's too. Gas.:)
True. Fortunately I can drive my UTV to a nearby gas station.
I believe Kubota sells diesel UTV's.
/ Educate me on zero turns #23
We switched from a gas Kawasaki Mule to a diesel Kubota RTV-X. Now the 3 tractors, the ZD1211 ZTR, and the RTV-X are all diesels. They get refilled from a 58-gallon John Dow fuel pod on a small trailer. The chainsaws, blowers, the weed eater, and the pole saw are all battery powered. The only gas motor left is a small 50CC Honda on the pasture vacuum. A gallon of gas goes a long way.
/ Educate me on zero turns #24
Are you using the electric chainsaw to cut firewood? or is it just for cleaning up after storms?
I can see a battery power being good to have in the UTV when driving around the trails of a property. Certainly for a lot of stop/start cutting. The perils of a gas powered saw is always starting them. It's even worse with todays saws, if they don't get run long enough for a second hot start. My Husky 550 is great on a cold start and a hot start. When it's only run a few minutes and then I try to restart is usually where the issue is.
Snap-On Zeus Diagnostic Machine (A63689)
Snap-On Zeus...
Coleman Sky Lodge Instant Screen House (A62613)
Coleman Sky Lodge...
2201SFL (A64553)
2201SFL (A64553)
2016 WEILER P385A ASPHALT PAVER (A63276)
2016 WEILER P385A...
2018 International DuraStar 4300 26ft. Box Truck (A61573)
2018 International...
2015 IC Corporation PB105 School Bus (A61568)
2015 IC...
