Username Taken
- Joined
- Jan 4, 2019
- Messages
- 1,450
- Location
- S Florida Winter/Michigan Summer
- Tractor
- Kioti CX2510 HST
About the only 'grief' ethanol was causing in automobiles was in some of the cheaper plastic intake manifolds made by generic motors. Especially Cadillac. And that took tens of thousands of miles to show up.Nearly all of the last 36 posts are needless spinning of wheels and distractions from the main underlying truth & problem:
- The govt once had what seemed like a well intentioned thrust to put ethanol in gasoline. Renewable fuels. More supply.
- Within 10 years or less from starting the experiment, every technically informed person in the world knew several things:
- That ethanol was causing major grief with small engines, chain saws, boat motors, etc. as well as reduced efficiency.
- That ethanol was putting upward pressure on food costs (meat, anything with corn in it, etc.)
- That , worst of all, it takes (total picture) more fossil fuel to make a gallon of ethanol tainted gas than it does to leave it alone and make plain old gasoline (!!!) so the underlying advertised purpose was hurt rather than aided. FAILURE.
- That the govt will never ever admit making a major mistake and rescind it.
- That the only people making very much off the process are companies mixing the gas (I read around $150M/year) and big AG companies that are about as much like farmers as you and I are like cats.
- And in my current frame of mind I add, "Duh!!"
When ethanol is made, they remove the liquids from it. They don't want anything else. Pieces of corn tend to get clogged in today's fuel injectors. What's left over is turned into animal feed. Net loss -- Zero.
Bullet point number 3 is news to me. And likely to the rest of the world.
#4 is on target. And it's a shame that government is so blind, so uncaring about the needs of The People that they have earned the distrust.
Yes, Big Ag is making a butt-load of money on it. So, what else is new? They're the biggest Welfare Queens in the Country.
