Drywall question
/ Drywall question #1
KubotaSteve
Platinum Member
eastern panhandle of WV
Kubota B7800 with loaded R-4s
I'm getting ready to add a mudroom and garage to my house. In the rules and regs. I got from the county they state that the garage has to have 1 hour fire resistant drywall on the wall connecting to the mudroom. I've never seen or heard of fire resistant drywall. Are they talking about a standard drywall that will resist fire for that long? If so what thickness would that be?
Our county has implemented new codes recently so I just want to make sure I get everything right.
/ Drywall question #2
I am not positive but I think that means it must be 5/8" thick on that wall.
The other walls can be thinner, like 1/2", but most people use 5/8" anyway.
/ Drywall question #3
Fire Resistance drywall is 5/8s and will be stamped Fire Resistance. Up here in the Northeast it’s about $7.25 a sheet and heavy to handle. Although no building codes in the town of VT that I am building in, I’m using 5/8s in the garage under, boiler room and main level, with the exception of ½ in on the 18ft cathedral ceilings. Drywall also comes in ½ in. and 3/8s (3/8s is flimsy) but is not categorized as Fire Resistance. I’m not familiar with ¼ in.
/ Drywall question #4
There is also a paperless drywall available... no mildew problems.
mark
/ Drywall question #5
5/8's. And, the entire wall of the garage must be completely taped and sealed, even if it is an unfinished garage. California has been like that for a long time.
As mentioned, it can be heavy, especially in 12' sheets.
/ Drywall question
Thanks for the help fellas.
I understand the reasons for these codes, but they can be a pain!!!!
/ Drywall question #7
I can handle 1/2" 4'x8' sheets easily by myself. Especially if I use a "kicker" to lift onto the wall. 5/8" is a strain, but doable, if they are not going on the ceiling.
I would definitely need a helper to handle 4' x 12' sheets of either thickness, and the 5/8 would be no fun at all.
I am an official geezer (62), but in pretty good shape for that age.
/ Drywall question #8
A drywall lift is the only way to go. 5/8" X 12' Type X for 1 hour fire rating is a piece of cake to hang on the ceiling. The hardest part is getting it on the lift if by yourself.
/ Drywall question #9
Check out this web site for design. The type of board, MUST BE TYPE X, and the nail pattern is very important.
Design Code For Acceptance 3 - Fire Rated Wood Floor and Wall Assemblies
See bottom of the page for designs as below.
2 x 6 wall
. Framing - Nominal 2x6 wood studs, spaced 16 in. o.c., double top plates, single bottom plate
2. Sheathing - 5/8 in. Type X gypsum wallboard, 4 ft. wide, applied horizontally, unblocked. Horizontal application of wallboard represents the direction of least fire resistance as opposed to vertical application.
3. Fasteners - 2-1/4 in. Type S drywall screws, spaced 7 in. o.c.
4. Joints and Fastener Heads - Wallboard joints covered with paper tape and joint compound, fastener heads covered with joint compound
2x4 wall
1. Framing - Nominal 2x4 wood studs, spaced 16 in. o.c., double top plates, single bottom plate
3. Insulation - 3-1/2 in. thick mineral wool insulation (2.5 pcf, nominal)
4. Fasteners - 2-1/4 in. Type S drywall screws, spaced 12 in. o.c.
5. Joints and Fastener Heads - Wallboard joints covered with paper tape and joint compound, fastener heads covered with joint compound
2007 Chevrolet Silverado 1500 Truck (A63116)
2007 Chevrolet...
NEW Landhonor Diesel Fuel Transfer Pump (A62679)
NEW Landhonor...
Skid Steer Deluxe Hitch Plate (A65640)
Skid Steer Deluxe...
2010 INTERNATIONAL WORKSTAR 7400 BUCKET TRUCK (A65643)
2010 INTERNATIONAL...
WW Poratable Creep Feeder (A66408)
WW Poratable Creep...
Bush Hog 285 3-Pt Rotary Cutting Mower (A66285)
Bush Hog 285 3-Pt...
