Drywall question
/ Drywall question #1
KubotaSteve
Platinum Member
eastern panhandle of WV
Kubota B7800 with loaded R-4s
I'm getting ready to add a mudroom and garage to my house. In the rules and regs. I got from the county they state that the garage has to have 1 hour fire resistant drywall on the wall connecting to the mudroom. I've never seen or heard of fire resistant drywall. Are they talking about a standard drywall that will resist fire for that long? If so what thickness would that be?
Our county has implemented new codes recently so I just want to make sure I get everything right.
/ Drywall question #2
I am not positive but I think that means it must be 5/8" thick on that wall.
The other walls can be thinner, like 1/2", but most people use 5/8" anyway.
/ Drywall question #3
Fire Resistance drywall is 5/8s and will be stamped Fire Resistance. Up here in the Northeast it’s about $7.25 a sheet and heavy to handle. Although no building codes in the town of VT that I am building in, I’m using 5/8s in the garage under, boiler room and main level, with the exception of ½ in on the 18ft cathedral ceilings. Drywall also comes in ½ in. and 3/8s (3/8s is flimsy) but is not categorized as Fire Resistance. I’m not familiar with ¼ in.
/ Drywall question #4
There is also a paperless drywall available... no mildew problems.
mark
/ Drywall question #5
5/8's. And, the entire wall of the garage must be completely taped and sealed, even if it is an unfinished garage. California has been like that for a long time.
As mentioned, it can be heavy, especially in 12' sheets.
/ Drywall question
Thanks for the help fellas.
I understand the reasons for these codes, but they can be a pain!!!!
/ Drywall question #7
I can handle 1/2" 4'x8' sheets easily by myself. Especially if I use a "kicker" to lift onto the wall. 5/8" is a strain, but doable, if they are not going on the ceiling.
I would definitely need a helper to handle 4' x 12' sheets of either thickness, and the 5/8 would be no fun at all.
I am an official geezer (62), but in pretty good shape for that age.
/ Drywall question #8
A drywall lift is the only way to go. 5/8" X 12' Type X for 1 hour fire rating is a piece of cake to hang on the ceiling. The hardest part is getting it on the lift if by yourself.
/ Drywall question #9
Check out this web site for design. The type of board, MUST BE TYPE X, and the nail pattern is very important.
Design Code For Acceptance 3 - Fire Rated Wood Floor and Wall Assemblies
See bottom of the page for designs as below.
2 x 6 wall
. Framing - Nominal 2x6 wood studs, spaced 16 in. o.c., double top plates, single bottom plate
2. Sheathing - 5/8 in. Type X gypsum wallboard, 4 ft. wide, applied horizontally, unblocked. Horizontal application of wallboard represents the direction of least fire resistance as opposed to vertical application.
3. Fasteners - 2-1/4 in. Type S drywall screws, spaced 7 in. o.c.
4. Joints and Fastener Heads - Wallboard joints covered with paper tape and joint compound, fastener heads covered with joint compound
2x4 wall
1. Framing - Nominal 2x4 wood studs, spaced 16 in. o.c., double top plates, single bottom plate
3. Insulation - 3-1/2 in. thick mineral wool insulation (2.5 pcf, nominal)
4. Fasteners - 2-1/4 in. Type S drywall screws, spaced 12 in. o.c.
5. Joints and Fastener Heads - Wallboard joints covered with paper tape and joint compound, fastener heads covered with joint compound
Year: 2018 Make: Towmaster Model: TC-16 Vehicle Type: Trailer Mileage: Plate: Body Type: Trim Lev... (A61567)
Year: 2018 Make...
John Deere 410D Backhoe (A62679)
John Deere 410D...
2016 Ford F-150 Pickup Truck, VIN # 1FTEW1EG0GKE69622 (A65563)
2016 Ford F-150...
Two (2) John Deere 5000-Series Tractor Grill Guards (A65640)
Two (2) John Deere...
STIHL HT103 POLE SAW (A62613)
STIHL HT103 POLE...
2007 DRAGON 130BBL VAC TRAILER (A60736)
2007 DRAGON 130BBL...
