Ditch Witch C99
/ Ditch Witch C99 #161
I see this is still an active topic. I picked up a c99 and could sure use the parts and service manuals if that is possible. Thank you.
/ Ditch Witch C99 #164
Hey guys! I just bought a C99 Ditch Witch in fairly neglected shape. I am hoping you might be able to sent me an email of the manuals you have? I sure would appreciate it. kurtlondon123@gmail.com.
/ Ditch Witch C99 #168
They are on their way. Let us know how it goes.
Thank you for the manuals. I really appreciate that. The C99 seems to be mostly all there but is pretty rough. The ignition switch and wiring is gone so I haven't been able to check for spark. Also the pull rope does not engage when I pull it so I haven't been able to check compression. Tires were flat and I aired them up. They seem to be holding air at least.
/ Ditch Witch C99 #169
I am needing to get an air filter element for the Ditch Witch C99. The one I have is the round dry element filter and it is totally shot. Cant seem to find any place that sells them. I would appreciate any information.
/ Ditch Witch C99 #170
Got some time to work on the ditch witch today. Found this setup for a recoil starter rope instead of a sheave type. Of course the flyweights are rusted and unmovable so have to clean and lube that. I put a socket on the crank bolt and was able to get it to turn, but only about a quarter turn. Can turn it back and forth easily but only about that quarter turn. After that quarter turn in either direction it stops hard. I have the sparkplug out so nothing is compressing. Does anyone have any ideas about what is stopping the crank turning?
/ Ditch Witch C99 #171
I got the Wisconsin engine on the C99 to free up today. It is making full revolutions now. I adjusted the planetary gear selector and it freed up after that. So i guess that was engaged to the engine and stopping it from turning.
/ Ditch Witch C99 #172
I got the recoil starter rope cleaned and lubricated so that the fly weights would engage the crank again. It works but not well really. The weights only engage after the rope is pulled fast enough (about half way out). Then you only have about half the rope left to start the crank turning. I may need to convert it to just a sheave setup. I guess the crank not turning completely was because of the reducer gearset. I adjusted the lever and was able to get the crank turning complete revolutions. I got a look at the magneto today ...it was pretty crusty. I sanded the points and tried to get a spark with a spark plug tester light but it was no good. Time for a magneto rebuild I'm guessing. I got the carb off and dunked it in a can of carb cleaner for overnight.
/ Ditch Witch C99 #173
I'm guessing that this thread is of no interest to anyone on here since I have gotten no replies to my ongoing posts. So I'm ending my posts.
/ Ditch Witch C99 #174
Not many of us have this particular model, but that doesn't mean we aren't interested, or at least I am. But my trencher isn't a DitchWhich.
Good luck on the rebuild.
All the best,
Peter
/ Ditch Witch C99 #177
HI All,
New to the Ditch Witch C 99 Club ! so now we are +1 and growing LOL
My baby needs a little TLC so I was hoping to get the PDF manual / Parts Break down if possible ...
My email address is: Andyinchville1@yahoo.com (yes, the 1 is correct)
Thanks in advance for any and all help .... I'd post a pic but will have to learn how !
Thanks
Andrew
/ Ditch Witch C99 #178
HI All,
Thanks
Andrew
Welcome to TBN Andrew. Gimme a minute and I will get them off to you.
/ Ditch Witch C99 #179
hello, another new guy here. I'm looking for a part number for the points in my c99. I could use the manuals too, if any are still available.
/ Ditch Witch C99 #180
I will send the manuals along later today. PM me with your email address. You can get the points from Ditch Witch. their slogan is something like, "Every part for every machine ever." Meanwhile, you might be able to get them cheaper elsewhere. I have the engine manual which I will send with the rest later today,, or soon after you email address arrives.
