Ditch Witch C99
   / Ditch Witch C99 #161
I see this is still an active topic. I picked up a c99 and could sure use the parts and service manuals if that is possible. Thank you.
   / Ditch Witch C99 #164
Hey guys! I just bought a C99 Ditch Witch in fairly neglected shape. I am hoping you might be able to sent me an email of the manuals you have? I sure would appreciate it. kurtlondon123@gmail.com.
   / Ditch Witch C99 #168
They are on their way. Let us know how it goes.
Thank you for the manuals. I really appreciate that. The C99 seems to be mostly all there but is pretty rough. The ignition switch and wiring is gone so I haven't been able to check for spark. Also the pull rope does not engage when I pull it so I haven't been able to check compression. Tires were flat and I aired them up. They seem to be holding air at least.
   / Ditch Witch C99 #169
I am needing to get an air filter element for the Ditch Witch C99. The one I have is the round dry element filter and it is totally shot. Cant seem to find any place that sells them. I would appreciate any information.
   / Ditch Witch C99 #170
Got some time to work on the ditch witch today. Found this setup for a recoil starter rope instead of a sheave type. Of course the flyweights are rusted and unmovable so have to clean and lube that. I put a socket on the crank bolt and was able to get it to turn, but only about a quarter turn. Can turn it back and forth easily but only about that quarter turn. After that quarter turn in either direction it stops hard. I have the sparkplug out so nothing is compressing. Does anyone have any ideas about what is stopping the crank turning?
2017 John Deere 1025R Tractor - 626 Engine Hours (A56435)
2017 John Deere...
2014 VOLVO VHD DAYCAB (A58214)
2014 VOLVO VHD...
2021 Caterpillar 272D3XE Compact Wheel Loader Skid Steer (A55973)
2021 Caterpillar...
LOT: (50) 14 Oz. Tubes of Star Fire Multi-Purpose EP 2 Grease (A59076)
LOT: (50) 14 Oz...
New Landhonor Heavy Duty Plate Compactor (A59000)
New Landhonor...
New Wolverine 72in Skid Steer Brush Cutter (A59000)
New Wolverine 72in...
