Ditch Witch C99
/ Ditch Witch C99 #151
Hi Dave,
This is Don Young. Did you get my PM request for a copy of your manuals for the C99? I couldn't tell if it got sent or not. I'll try sending it again just to be sure. Thanks, Don
Hi Don,
Just noticed the activity. Still looking for the manuals? I can send them if you like. I have them all, including the engine parts and service manuals.
Gary N.
/ Ditch Witch C99 #155
/ Ditch Witch C99 #157
It’s been a fun rebuild so far.
We have different ideas of fun :). I have zero patience for this kind of work but I'm persistent :). A year and a half later I am back at it.
I fixed it enough to do a couple hundred feet of trenching at my house and then parked it. I think I'm going to attempt to take the planetary gear apart and see if I can get it into drive. It's too heavy to push/pull around. It started right up after sitting for 18 months through two AZ summers. I stopped in here for a refresher course.
/ Ditch Witch C99 #158
What kind of drive issues are you having? On mine, the planetary gearbox is welded together. The problem was that the part that was supposed to engage it would pop out. The box would spin a turn, then re engage for a short bit, then pop out again. A bit of grinding to change the angle to keep it engaged did the trick.
/ Ditch Witch C99 #159
Hey I swear I have been looking all over for the maintenance manual for this thing! I have a C99 down right now because one of the drive axle bearings broke off the bracket that held it to the body and bent all up on me. Can't figure out how to get those retainer rings off the axle rod. If you see this can you send a copy of the maintenance manual to Ernie.godin0453@kirtland.edu ? Thanks!
2016 Yanmar VIO25 (A60462)
2016 Yanmar VIO25...
JOHN DEERE 750 (A58214)
JOHN DEERE 750...
CATERPILLAR 926M WHEEL LOADER (A60429)
CATERPILLAR 926M...
Kubota SVL97-2 (A60462)
Kubota SVL97-2...
Deere 333E (A60462)
Deere 333E (A60462)
2019 John Deere 6125R (A60462)
2019 John Deere...
