Ditch Witch C99
/ Ditch Witch C99 #202
I have sent the manuals. Put up a note and maybe some pics to let us know how it turns out.
-Gary
Ok will do, here is where i am now.
/ Ditch Witch C99 #203
Just wondering if anyone has had any issues with the slide bar that tightens the dig chain to freeze? i can't get it to loosen in order to take the chain off.
/ Ditch Witch C99 #205
When i engage the chain it turn just a smidge and then starts squealing like its binding.
/ Ditch Witch C99 #207
I suspected a bearing somewhere but where to find parts for these anymore and is it worth fixing i have 400 in it running
/ Ditch Witch C99 #208
The directional selector is a bit weird too, its very loose operating. Reverse works ok, but the notch that engages forward falls in and out as it goes forward it doesn't stay in its gear.
/ Ditch Witch C99 #209
Ditch Witch's slogan is, "Any part for any machine ever." You can get it from them although it can be pricey. Most bearings etc. on these machines are off the shelf type items so you can measure it up and get it anywhere.
/ Ditch Witch C99 #210
Sounds good! As soon as i can get the slide move so i can get the chain off ill start in it.
/ Ditch Witch C99 #211
I hate to be "That Guy," but I would sure appreciate a copy of the manual. eric@weavercomm.com
I just got a C99 with a trailer for $600 off Facebook. I changed the oil, put a new spark plug in, and of course, no spark.
Further investigation revealed that the points were corroded to beat the band. New points ordered from ebay, hopefully I can get them installed next week and see if I can get this rascal up and running. I have a waterstove to install, amongst other projects!
/ Ditch Witch C99 #213
Gary, THANK YOU for the kind gift of the manual for my $600 no-spark C99!
Apparently I ordered the wrong points. Or the chinaman packing the box did. Who knows. But condenser oughta work. Wire up condenser, wire up new kill switch (Old one was jut a wire to twist to another wire shorted to ground)
File old points. Adjust gap to .015 like the book says. Won't stay adjusted. Screw is all the way in, still isn't holding points still. Put a little washer to give screw a little more thickness, works fine. Points are now adjusted right, filed straight. Gap new spark plug at .030 like the book says.
And for the big moment - Pull the rope. Guess what? We have spark! But no chug-chug-chug of combustion. Hmmm...
Further investigation revealed that the carb is dead. Gas is not getting through, nor is a snort of ether. Take carb off, it is one solid piece I guess from being out in the weather. The choke will move some, but the intake butterfly is frozen solid. Solid. Was going to rebuild it, but I might order a replacement updraft carb. With the carb off, a little spray of ether right into the intake got me a little combustion, which was what I was hoping for.
Leaky gas tanks removed and thrown in metal scrap trailer. New tank will be installed when I get carb situated.
Just another day at The Land of a Thousand Projects!
Photos show before and after, showing the new condenser, dressed-up wiring, and kill switch.
/ Ditch Witch C99 #214
Nice! I'm always nervous using ether as a start aid because of the potential for engine damage. I check through my collection of spray cans for some flammable lube and use that. So far so good. One guy here did a relining of his gas tank. I had never heard of that so did some looking. Turns out that there is stuff out there just for that. Given that the carb is cast iron I would hope you could free up the stuck parts. I have a Kohler with aluminum carb on a firewood processor. The choke shaft froze up on that pretty much right away. I put a tire stem in the intake manifold, took the core out. I spray the above mentioned flammable lube in, start it up and screw the cap on. What fun! I used starting fluid a couple times but in each case I heard the death knock of detonation so I quit using it. I suppose sone gas in a squirt bottle would also work. Let's see a trench!
/ Ditch Witch C99 #215
I used starting fluid just to triage the engine to make sure I wasn't getting into a bigger project than I had time for. I am careful with it, but it served its purpose well in this case.
I ordered a chinesium carb that ought to be next week. Hopefully trenching will start shortly thereafter! I have a carb rebuilt kit and I will probably dig into it at some point, but it will be a big production to get it all torn down without damaging anything, I think.
The original carb is soaking in penetrating oil to see if I can do anything with it.
/ Ditch Witch C99 #216
Instructions for adjusting the Zenith updraft carb
  • Zenith Updraft Carb.pdf
/ Ditch Witch C99 #218
More info - The drive belts on the trencher were old as the hills, so I went to the friendly folks at my local NAPA to find some new ones. They measured the old one out at 65 1/2 inches, and we figured that it was stretched a little bit, so I got a B62 (65 inch) belt. It fit fine. See photos for NAPA belt part number, etc.
/ Ditch Witch C99 #219
Making progress. Got a working carb on it yet? Planning to run it with just one belt? Interesting experiment. Looking forward to hearing how it holds up. I do hear that Napa puts out a quality belt.
/ Ditch Witch C99 #220
Got the new carb and got it running Sunday afternoon. I'm waiting on a few new parts that should be here today to bolt it all back together and lube everything that I can lube and document what I did. NAPA only had 1 belt in stock, but I paid for 2 more and they will be in today. Apparently, Gates makes the NAPA belts, at least for my favorite NAPA store. More to come!
