Dimensions for storage
/ Dimensions for storage #1
lj04
VA
JD 955
Can anyone tell me what size of building I would need to store a 4520 w/ FEL and BH? Also, what dimensions would the door have to be?
/ Dimensions for storage #2
Height and width will depend on your tires.
What I listed below (from the 4520 manual) lists different tire types.
For the overall length, add 10-12 feet for the loader/backhoe.
I'd suggest 12" extra on both sides of the door and 3"-5" for the height (minimum).
Here's the basic tractor dimensions (not including FEL or backhoe):
Dimensions
Wheelbase 1.8 m (71.5 in.)
Overall Length w/ 3-Point Hitch 3.3 m (128.2 in.)
Overall Width w/ R1 Tires (Minimum) 1.7 m (65.6 in.)
Overall Width w/ R1 Tires (Maximum) 2.3 m (89.1 in.)
Overall Width w/ R3 Tires (Minimum) 1.9 m (74 in.)
Overall Width w/ R3 Tires (Maximum) 2.2 m (86.6 in.)
Overall Width w/ R4 Tires (Minimum) 1.7 m (68.4 in.)
Overall Width w/ R4 Tires (Maximum) 2.3 m (91.9 in.)
Overall Width w/ Golf Tires (Minimum) 2.1 m (81.4 in.)
Overall Width w/ Golf Tires (Maximum) 2.2 m (86.6 in.)
Inside Width w/ R1 Tires (Minimum) 94 cm (37 in.)
Inside Width w/ R1 Tires (Maximum) 1.5 m (60.4 in.)
Inside Width w/ R3 Tires (Minimum) 94 cm (37 in.)
Inside Width w/ R3 Tires (Maximum) 1.2 m (48.1 in.)
Inside Width w/ R4 Tires (Minimum) 87 cm (34.2 in.)
Inside Width w/ R4 Tires (Maximum) 1.5 m (57.7 in.)
Inside Width w/ Golf Tires (Minimum) 90 cm (35.6 in.)
Inside Width w/ Golf Tires (Maximum) 1.0 m (40.8 in.)
Height From Ground (Tractor without cab, with standard R1 tires)
To Top of Hood 1.6 m (62 in.)
To Top of Folding ROPS 2.5 m (97.2 in.)
Height From Ground (Tractor with Cab, R3 tires)
To Top of Cab 2.35 m (92.4 in.)
Weight
All Models (without cab) 1679 kg (3700 lb)
All Models (with cab) 1970 kg (4345 lb)
/ Dimensions for storage #3
My 4520: R4 tires, 448 BH, 4in 1 on 400cx.
19ft 9 inches long. 6ft 3inches wide (4in1, rear tires.) 7ft 11inches Tall to top of folding rops. If you want to store BH inside, off of tractor, add 5 ft minimum. I think Roy's additional space for sides, top is about correct. You wouldn't want it too tight. While you could fit it in tight, I would err on the side of larger. I know someone who is storing one of these in a 20ft shipping container (rops down). It works, but I wouldn't want to do it myself.
/ Dimensions for storage #4
Regarding the door, while a "standard" garage door (cars) is 8' tall, another common height is 8'6". It cost me $250 more on a 12' wide door to get that extra height, and about $200 more on a 9' wide door to get it.
There is a "low clearance" lift set of tracks you can get too, so if the structure that will get the door takes a standard set of tracks/rails, then you can most likely go with the taller door and the low clearance tracks.
So if you're in that general size/range of door (typical garage door) ask for the 8'6" height version.
Pete
Thanks for the replies. I guess I'm going to need a little bit bigger area than I originally was thinking.
This was only going to be temporary storage but it may have to be something more permanent. A used shipping container would have been nice but that seems like it may be tight.
/ Dimensions for storage #6
/ Dimensions for storage #7
If it is only temp, keep in mind the FEL bucket could be removed to gain a bit on length, the ROPS if OS model can be folded to reduce height and the BH boom can be lowered a bit to reduce height.
Just did that with the ROPS / BH in order to drive into a standard garage with a skid of tiles. In addition to shipping containers, used truck bodies may represent a temp option as well.
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
2000 Freightliner Classic XL T/A Sleeper Cab Truck Tractor (A66736)
2000 Freightliner...
2012 Volkswagen Passat (A66738)
2012 Volkswagen...
2011 CHANDLER TRI AXLE SPD-18 WATER HEATING TRAILER (A67714)
2011 CHANDLER TRI...
2011 FORD CROWN VICTORIA (A66091)
2011 FORD CROWN...
2009 CHEVROLET SILVERADO 3500 TOW TRUCK (A65057)
2009 CHEVROLET...
