Dimensions for storage
/ Dimensions for storage #1
lj04
Member
VA
JD 955
Can anyone tell me what size of building I would need to store a 4520 w/ FEL and BH? Also, what dimensions would the door have to be?
/ Dimensions for storage #2
Height and width will depend on your tires.
What I listed below (from the 4520 manual) lists different tire types.
For the overall length, add 10-12 feet for the loader/backhoe.
I'd suggest 12" extra on both sides of the door and 3"-5" for the height (minimum).
Here's the basic tractor dimensions (not including FEL or backhoe):
Dimensions
Wheelbase 1.8 m (71.5 in.)
Overall Length w/ 3-Point Hitch 3.3 m (128.2 in.)
Overall Width w/ R1 Tires (Minimum) 1.7 m (65.6 in.)
Overall Width w/ R1 Tires (Maximum) 2.3 m (89.1 in.)
Overall Width w/ R3 Tires (Minimum) 1.9 m (74 in.)
Overall Width w/ R3 Tires (Maximum) 2.2 m (86.6 in.)
Overall Width w/ R4 Tires (Minimum) 1.7 m (68.4 in.)
Overall Width w/ R4 Tires (Maximum) 2.3 m (91.9 in.)
Overall Width w/ Golf Tires (Minimum) 2.1 m (81.4 in.)
Overall Width w/ Golf Tires (Maximum) 2.2 m (86.6 in.)
Inside Width w/ R1 Tires (Minimum) 94 cm (37 in.)
Inside Width w/ R1 Tires (Maximum) 1.5 m (60.4 in.)
Inside Width w/ R3 Tires (Minimum) 94 cm (37 in.)
Inside Width w/ R3 Tires (Maximum) 1.2 m (48.1 in.)
Inside Width w/ R4 Tires (Minimum) 87 cm (34.2 in.)
Inside Width w/ R4 Tires (Maximum) 1.5 m (57.7 in.)
Inside Width w/ Golf Tires (Minimum) 90 cm (35.6 in.)
Inside Width w/ Golf Tires (Maximum) 1.0 m (40.8 in.)
Height From Ground (Tractor without cab, with standard R1 tires)
To Top of Hood 1.6 m (62 in.)
To Top of Folding ROPS 2.5 m (97.2 in.)
Height From Ground (Tractor with Cab, R3 tires)
To Top of Cab 2.35 m (92.4 in.)
Weight
All Models (without cab) 1679 kg (3700 lb)
All Models (with cab) 1970 kg (4345 lb)
/ Dimensions for storage #3
My 4520: R4 tires, 448 BH, 4in 1 on 400cx.
19ft 9 inches long. 6ft 3inches wide (4in1, rear tires.) 7ft 11inches Tall to top of folding rops. If you want to store BH inside, off of tractor, add 5 ft minimum. I think Roy's additional space for sides, top is about correct. You wouldn't want it too tight. While you could fit it in tight, I would err on the side of larger. I know someone who is storing one of these in a 20ft shipping container (rops down). It works, but I wouldn't want to do it myself.
/ Dimensions for storage #4
Regarding the door, while a "standard" garage door (cars) is 8' tall, another common height is 8'6". It cost me $250 more on a 12' wide door to get that extra height, and about $200 more on a 9' wide door to get it.
There is a "low clearance" lift set of tracks you can get too, so if the structure that will get the door takes a standard set of tracks/rails, then you can most likely go with the taller door and the low clearance tracks.
So if you're in that general size/range of door (typical garage door) ask for the 8'6" height version.
Pete
Thanks for the replies. I guess I'm going to need a little bit bigger area than I originally was thinking.
This was only going to be temporary storage but it may have to be something more permanent. A used shipping container would have been nice but that seems like it may be tight.
/ Dimensions for storage #6
/ Dimensions for storage #7
If it is only temp, keep in mind the FEL bucket could be removed to gain a bit on length, the ROPS if OS model can be folded to reduce height and the BH boom can be lowered a bit to reduce height.
Just did that with the ROPS / BH in order to drive into a standard garage with a skid of tiles. In addition to shipping containers, used truck bodies may represent a temp option as well.
2023 Ford Explorer SUV (A66738)
2023 Ford Explorer...
2024 BOBCAT S76 R-SERIES SKID STEER (A64279)
2024 BOBCAT S76...
2023 VOLVO L90H WHEEL LOADER (A65053)
2023 VOLVO L90H...
GENERAC MOBILE  MTL65 LIGHT PLANT (INOPERABLE) (A68842)
GENERAC MOBILE...
Salvage Truck Frame (A64911)
Salvage Truck...
2019 HYUNDAI V12530152-AJS 53' 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
