Diesel Generator - Funny Smell
/ Diesel Generator - Funny Smell #1
Kyle241
Platinum Member
Eastern Ontario
Kubota MX5100
Hi everyone. We have a Kipor generator that we purchased over a year ago (would never have bought it had I done more research). We have not used it much, mainly for powertools for work on the garage however it is intended for failover when power goes out. The electricians hooked us up when we got it so no worries there. What I have found recently is that the smell coming from it is different, not sure how to describe but it's not the typical diesel smell. I filled it up with new diesel, checked the oil which is full so I am not sure what is wrong. I have only run it for a few minutes recently because of the smell and then quickly shut it down because it smells more like burning diesel. Also there is a lot more smoke coming from it than ever before and it does not go away even after a couple minutes of running. Any ideas?
Tks.
Kyle
/ Diesel Generator - Funny Smell #2
run it and see if the rings unseat and maybe itll stop smoking..carboned up rings probly from sitting...run it awhile long as its got oil in it itll be okay
/ Diesel Generator - Funny Smell #3
exactly where is the smoke coming from? exhaust? on the pipe? Sometimes a brand new unit, there is lightweight oil smeared on certain parts to prevent rust and running the gen is burning it off. I would take the cover off and start it up and watch for unusual smoke locations.
/ Diesel Generator - Funny Smell #4
Run it till it either blows up or quits smelling bad,,
/ Diesel Generator - Funny Smell #5
You got mice nesting in it somewhere? Mabey check the air intake. Burning diesel with not enough air would give you smoke.
The smoke is coming from the exhaust. It's been used enough over the past year that whatever 'new' smell it had is long gone. It was fine a few weeks back and then I tried it last weekend, and the smell and smoke was apparent. I tried it again this Friday and it's still doing it. There have been mice at it so possibly the air intake is blocked. I'll look at this as a possibility.
Tks!
2010 John Deere 1770NT Planter (A63109)
2010 John Deere...
karcher pressure washer (A61567)
karcher pressure...
213324 (A64279)
213324 (A64279)
2017 Ford F-250 4x4 Crew Cab Medical Service Truck (A61573)
2017 Ford F-250...
2020 Inifiniti Q 50 Sedan (A61574)
2020 Inifiniti Q...
2005 LEDWELL LW40ADC - 40' ALUMINUM FEED TRAILER (A63290)
2005 LEDWELL...
