Richard
Super Member
- Joined
- Apr 6, 2000
- Messages
- 5,088
- Location
- Knoxville, TN
- Tractor
- International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
I live in the boonies. Power goes out nearly once a week however, maybe for a blink of time or sometimes, for 2-3 hours. During a storm, the worst as I recall might have approached nearly a week. Brother in law (electrician) brought one over and hooked it up to help us get through that (winter AND we had his wheelchair bound niece here visiting, was a huge help!)
anyway...
I've always liked idea of putting a generator in but fight with where to put it. To try to describe situation in simple terms:
Square lot. House on back edge. Septic field is entire front/side yard. My presumption is the power line can't cross over the drain field. Other side of house is driveway. My power comes in on the OPPOSITE side of house, where the drain field is.
Was cutting yard other day and had a light bulb go off in my head.
In the very front of the house, is the on/ground transformer.
Could a generator be installed next to /near by the transformer. I am presuming the transfer box (whatever it's called to make sure a line man doesn't get fried) would be near the generator. So, could this be outside, near the power company's transformer. If their power is on, then power goes through transformer, through underground wire, into the house and life is good.
Power goes out and generator fires up, then the transfer switch blocks the transformer, generator is producing but is using the SAME UNDERGROUND wires that is already wired into the house?
It dawned on me that if this could be how it works, that could make this far more doable than I currently believe it to be.
I look around (and have a VERY visually minded wife) and conclude:
1. She's not going to want a generator on the side of house where the power actually enters. Truth be told, she wouldn't want a generator at all as it would be an eye-sore)
2. Difficult to put it on the non-power entry side of house as it complicates getting the power over to the input side of house.
3. Behind house, too close to property line, doubt I have space
4. Other than actual (gravel) driveway, all sides of house have flagstone sidewalk or patio making ripping it up, laying line, fixing flagstone a much larger project
(eyeballs current transformer)....but if I could have them splice things into the line already coming to house...... that could work.
But, COULD that work?
anyway...
