Deere 5210 7-Pin Trailer Plug
/ Deere 5210 7-Pin Trailer Plug #1
jgbanshee
PA
JD 310SE, 325G, 35G, 4300, 5300, 5210, 445, 450 Crawler, CAT D3B, Ford 2N, 7000, 5000, 4000su, 3610, 445D, 345C, 340B, 1100
I have the factory 7 pin round trailer/implement plug on the back of my 5210. I am looking to get 12V from it from one of the two accessory pins but there is no power at them. Does anyone know where the relay is or should be located for this? Thanks
/ Deere 5210 7-Pin Trailer Plug #2
I hope this 5X10 wiring diagram helps you.
  • 5X10wiring.pdf
/ Deere 5210 7-Pin Trailer Plug #3
Interesting. I could have sworn my 5310 had switched power and full time power. I could be confusing it with my new tractor but...that's not what that WD says.
/ Deere 5210 7-Pin Trailer Plug #4
I hope this helps as well.
  • accessory relay.pdf
Thanks JD5210. I have this info but I cannot physically locate the relays. Are they behind the instrument cluster?
/ Deere 5210 7-Pin Trailer Plug #6
If they aren't in the fuse block they are behind the instrument cluster.
/ Deere 5210 7-Pin Trailer Plug #7
If I remember correctly they can be found by removing green panel to the left of the instrument cluster. Looking at jdparts.com it looks like the part number is LVA13729. There 2 relays with the small part number, so for testing you should be able to switch them around.
UNUSED INDUSTRIAS AMERICA HYD POST PULLER (A60430)
UNUSED INDUSTRIAS...
1762 (A58375)
1762 (A58375)
3 BOTTOM TURN PLOW (A60430)
3 BOTTOM TURN PLOW...
2014 Chevrolet Express 3500 Cargo Van (A55852)
2014 Chevrolet...
(1) 18"X7' ADS DRAIN PIPE (A60432)
(1) 18"X7' ADS...
HYUNDAI HL730-7A WHEEL LOADER (A60429)
HYUNDAI HL730-7A...
