- Joined
- Aug 31, 2001
- Messages
- 65,979
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
Duplicate
1/2'' Copper is only 3/8'' id..
You aren't going to get much flow / volume supplying a home through a 3/8'' od line
The OP states its 1/2" from the city before the meter. Most places you can't change that without the city's approval.I think the problem is the 1/2 supply line. I would rerun it with at least 3/4 ideally 1". I would be surprised if that doesn't fix the problem.
Either the city doesn't have enough water to supply the homes, or they don't know what the're doing..
I had the same problem years ago. I was told by the city that everything from the City main to the house was mine. I had a 365' run of 3/4" copper. Problem was it "T"'d off to the neighbor. He flushed his toilet I couldn't get a drink until his tank filled. I bit the bullet & ran a new copper line. I wanted to use 4" but would have to pay a commercial rate for water. Too expensive. I ended up running 2&1/2". Biggest I could legally use for residential rate. When the City Inspector came out for final inspection before trench was backfilled he tried to tell me the line was too big. I showed him my permit, receipt for permit & a copy of the City Code showing I could use 2&1/2 inch. He went away saying he was going to look into it. Bottom line "GET IT IN WRITING'. It did fix the water pressure/volume problem. With a regular hose nozzle I stripped the old paint off the garage to repaint it. When you washed the car you had to be careful not to blow things off it that weren't supposed to come off. I had a couple of faucets blow off but just had to turn the knob off so water quit spraying on the ceiling. Bigger supply line should solve the problem in my experience.
