My well water is terrible. Should I just use pool water?
   / My well water is terrible. Should I just use pool water? #91
My experience is that just 100’ apart, a well can have totally different water qualities.
Interesting, with your demonstrated expertise in water, that you not know that you can’t dismiss localized water quality issues over an assessment of a large area internet data map.
Apparently you missed the next thing he said.... "Stranger things have happened."
   / My well water is terrible. Should I just use pool water? #92
Our well water is rough too, though not quite as extreme. I totally get why you’d consider using the pool as a buffer system. It’s actually a creative idea, especially with the off-gassing and sediment settling, but I’d be cautious. Pool chemicals, even at safe swimming levels, aren’t meant for daily consumption. Also, maintaining consistent water quality for drinking and bathing could get tricky.
Have you looked into more robust filtration setups through companies like american water resources? Some of their systems are designed specifically for harsh well conditions, and they might offer better long-term solutions than piecemealing stuff together. Still, I admire your outside-the-box thinking, it might just need a tweak or two to be viable.
   / My well water is terrible. Should I just use pool water? #93
@wilso so where are you located, and which version of the JD 5310 do you have?
@strantor any luck with your water?
All the best,
Peter
New/Unused Quick Attach Bale Spear (A57454)
New/Unused Quick...
2019 KUBOTA KX033-4 EXCAVATOR (A60429)
2019 KUBOTA...
Hot Pressure Washer Trailer (A59228)
Hot Pressure...
19008 (A56859)
19008 (A56859)
KBH 25T Tender (A56438)
KBH 25T Tender...
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A57024)
2023 NEW HOLLAND...
