cut a foldable ROPS?
/ cut a foldable ROPS? #1
twodogs
Pittsburgh, PA
Kubota B7800
I know, you aren't supposed to mess with the ROPS. I have pulled into my garage enough times that the thought has entered my head to have it cut & welded in place so that it would be rigid, but low enough to get in & out of my garage. Has anyone done it? There are welds on the ROPS setup as it came new. I figured that a good welder would make sure that it is welded correctly & safely.
/ cut a foldable ROPS? #3
You have a B7800 right? I believe they also come with a fixed ROPS that is a few inches shoorter than the folding ROPS. My B2710 with fixed ROPS and sun shade just barely fits thru my standard (whatever that is) height garage door. You might want to look into replacing the folding with a fixed.
/ cut a foldable ROPS? #5
The folding ROPS, part #SFB-F29A is 10.45 inches taller than the fixed ROPS (SFB-29A) according to Kubota. However, the folding ROPS is required if you use a Kubota backhoe.
/ cut a foldable ROPS? #6
And that is primarily so you don't crack your skull on the thing when using the backhoe, I believe. There may be some mount location issues, but I don't think the extra height has anything to do with the rollover function.
/ cut a foldable ROPS? #7
I'll bet you could find someone to trade you even up for your folding rops for their fixed rops.. then both would be happy.. and no rops certification would be voided..
Soundguy
/ cut a foldable ROPS? #8
I'm not telling you to cut yours, but I did cut mine.
Mine was a few inches to tall for one on my buildings, so I hacked it.
I'm sure mine, yours and the rest are at a tested safety height!
Anyway I do custom roll cages for off-roading as a side job so
shorting mine was simple and it's done in a manner that looks factory!
Come to think about it I never even run the pins in it...to each their own..
Gene
/ cut a foldable ROPS? #9
Me too Gene, I put a cage on my tractor as well as my Jeep.
/ cut a foldable ROPS? #11
Yep, Gold Bar Rim. Nice shop and Jeep, putting a cage in a TJ is a bit more of a challenge with the real car dash to deal with.
/ cut a foldable ROPS? #12
I know that remembering to lower the rops can be a challenge. I hae to remember to lower mine too! But it is a piece of safety equipment. In todays times god forbid something happen every lawyer and risk manager is looking for a way not to pay a claim. My opinion is to place a lable on the tractor, or hang a bell in front of the garage door so the rops hits it and rings to remind you to lower it.
2020 Peterbilt 567 Quint Dump (A62613)
2020 Peterbilt 567...
TERRA TRACK TRACKED WORK  VEHICLE
TERRA TRACK...
10 Lug Wheels Full Set (A57453)
10 Lug Wheels Full...
2014 John Deere 310SK 4x4 Extendahoe Loader Backhoe (A61572)
2014 John Deere...
2007 PETERBILT 379 6X4 T/A SLEEPER TRUCK TRACTOR (A59911)
2007 PETERBILT 379...
2019 VERMEER LP573XDT LOW PROFILE VACUUM TRAILER (A63276)
2019 VERMEER...
