In the winter, you have cold air that is much thicker, (denser), than it is in the summer. This means there is more air going into the engine when it cranks.
When you have more air than fuel, the mixture can get too lean for it to start.
Since there are generally no computers on these engines, you have to adjust the mixture yourself. You do that of course, by opening the throttle some. More fuel enriches the mixture back to the same level it would be in warm weather.
A good way to determine the proper throttle setting for cold weather starting, is to start cranking with the throttle at idle, and while cranking, slowly advance the throttle lever until the engine fires. Note the throttle setting the engine fired at, and you can try that as the starting point next time.
If the engine does not fire after 5-8 second of cranking, always stop, and return to heating the glow plugs again. Cranking until the battery dies only causes additional frustration.
Sometimes, when it's really cold, and depending on the condition of your engine, you may find you need to heat the glow plugs for 30 seconds or more, to get a good start.
To the OP: Diesel engines cool at low idle speed. You need a nice high idle speed to warm one up in cold weather efficiently. Can't tell you what that is, never owned one with a tach. Just open the throttle until it is running smoothly at a nice speed.
