sandman2234
Super Member
- Joined
- Dec 4, 2005
- Messages
- 6,834
- Location
- Jacksonville, Florida
- Tractor
- JD2555 and a few Allis Chalmers and now one Kubota
Newly purchased S/S safety wire bought for the job at hand should have no kinks in it, so that makes it 3 things wrong with S/S.
I wasn't thinking about using it in a plastic pipe. Although I have plastic in my garage, most of my experience has been with steel conduit, so the wire doesn't hurt the metal no matter how many curves you pulll it around. So for my use, down to 2 things.
S/S chips will cut you, and you never even realize it. Having a couple of lathes, and even more milling machines in my garage, (hobby use) I can vouch for that. However, I have never, ever been cut by a piece of safety wire. Not sure if it is the alloy, or the fact that all corners are curved, but a round piece of safety wire usually only cuts on the end, which is sharp.
Wire correctly manufactured should have no camber and an appropriate cast for the size of the wire and the spool it is wound onto. The roll of safety wire I have has a 34" cast, meaning if you cut several feet of it, and then remove one loop of it, as it is lying on the ground, the circle it makes has a 34" diameter. The cast is the amount one end raises up off the floor. Having been in the QA end of a wire manufacturer for the last 7 years of a 15 year employment, I am able to recognise good and bad wire charactistics.
I was just thinking that when you start to pull all the wires in a single run, just add a piece of safety wire and it will be there long after any string I have ever dealt with. Pulling the safety wire after the run has been energized is not a consideration, and pulling new wires thru it while anything is still hot is asking for trouble. People do it all the time, but not with residential electrical.
David from jax
David from jax
