Need help with pole barn overhead detail - Concrete next week!
/ Need help with pole barn overhead detail - Concrete next week! #21
I'm not talking about not being able to cut on a line, I'm talking about the waviness that happens when cutting with shears.
Use a square and box cutter/razor knife to score the tin. It’s the tool that is used to cut most tin/stainless for flashing and other metal work, otherwise a floor or table mounted cutter is used (they look similar to a metal brake used for bending).
If you score it a few good times and your line is straight, all you have to do is fold the flashing and it will snap off. Use a new clean blade, run both directions if it’s a thicker flashing and you can also use the speed square to hold the upper portion down while you bend the bottom portion. Sometimes on thicker flashing you will need a couple bends to get that clean snap, but it works better and much faster than tin snips.
/ Need help with pole barn overhead detail - Concrete next week! #22
Will post a pic of the garage door threshold using pipe..
208316 (A58375)
208316 (A58375)
207280 (A52708)
207280 (A52708)
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A58214)
2011 MAGNUM...
2007 KOMATSU GALEO D39PX-21 CRAWLER DOZER (A60429)
2007 KOMATSU GALEO...
2013 Infiniti JX35 v SUV (A59231)
2013 Infiniti JX35...
2020 Caterpillar D5K2 LGP Crawler Tractor Dozer (A56857)
2020 Caterpillar...
