Compact Tractors are Designed All Wrong
/ Compact Tractors are Designed All Wrong #201
Well, efficient enough to have removed the backhoe from all worksites the last 25 years. Backhoes are not efficient, takes way to much space, can't go 360 around, horrible in the terrain, can't climbe, sinks like a rock I wet conditions. And steelbelts is hard to beat when it comes to taking punishment. And is road use important you have wheel excavators.
/ Compact Tractors are Designed All Wrong #202
/ Compact Tractors are Designed All Wrong #203
I see skid steers, backhoes, and excavators on the same construction site all the time. Backhoes pretty much own the small construction sites. Cityç—´ will never give up their backhoes. Good luck driving the mini a couple miles.
Its the same around here.
Most Townships still use backhoes in my area also.
The backhoes are used to load the trucks (salt/anti skid, gravel, Etc.) and can travel relatively quick and easy from road, to road within the township for maintaining roads/ditch's without needing to be hauled to every job by truck.
/ Compact Tractors are Designed All Wrong #204
/ Compact Tractors are Designed All Wrong #205
Wheeled excavators are uncommon here. If the travel speed is better I’d rather have that over tracks.
/ Compact Tractors are Designed All Wrong #206
Top speed ca 35km/h
/ Compact Tractors are Designed All Wrong #207
Do that steer or skid? That picture appears to steer. That looks like a much more useful setup to me. It should be cheaper to buy and maintain, moves faster and doesn’t tear up the grass.
/ Compact Tractors are Designed All Wrong #208
It has a front axle with steering and 4WD.
/ Compact Tractors are Designed All Wrong #210
/ Compact Tractors are Designed All Wrong #211
I’ve never seen one of those in person if you don’t count log loaders.
/ Compact Tractors are Designed All Wrong #212
They are fairly common around here for cleaning out ditches, many of them were made by Drott back in the day.
Aaron Z
/ Compact Tractors are Designed All Wrong #213
We’ve got big tandem axel trucks with booms on them for cleaning ditches. The wheeled excavator seems more practical for that.IMG_4136.JPG
/ Compact Tractors are Designed All Wrong #214
Here it very common on machines doing finishing work and on wheeled machines since they are used as a multipurpose machine.
/ Compact Tractors are Designed All Wrong #215
This type of bucket with side angeling I suppose is in use over there?hydrauliskepusseskuff.jpeg
/ Compact Tractors are Designed All Wrong #216
/ Compact Tractors are Designed All Wrong #218
Our city street department has one (maybe 2) of those. It's easy to get it from site to site and functions very well.
The ones they have here, are pretty much dedicated to ditching. That way they can run down the road cleaning out ditches and they don't have to dedicate a truck and trailer to it to move it back and forth each day.
Aaron Z
/ Compact Tractors are Designed All Wrong #219
That page you linked said that thing weighed 85,000 pounds. It doesn’t look that big. Am I underestimating the size or is the picture wrong?
/ Compact Tractors are Designed All Wrong #220
I didn't link to anything. :confused3:
KMC 6R HEAVY DUTY ROTARY TILLER (A64276)
KMC 6R HEAVY DUTY...
2023 VOLVO ECR25 ELECTRIC EXCAVATOR (A60429)
2023 VOLVO ECR25...
MOULINE 260 BAGEL SLICER (A64281)
MOULINE 260 BAGEL...
UNUSED WOLVERINE 7' FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
Kubota LA525 Front Loader Tractor Arm Attachment (A59228)
Kubota LA525 Front...
1992 Rammax Trench roller and Extra Set of Drums (A62613)
1992 Rammax Trench...
