Cleaning chains
/ Cleaning chains #1
tjkubota93
Arlington, TN
Kubota bx1860
I have three or four chains with plenty of life left, but they are kinda dirty (especially the one I used to cut on stumps I dug up). I sharpened them and tossed the nasty ones in a pie plate full of diesel.
I know they don't have to be super clean and I've never cleaned one before. But it can't hurt. I do regularly clean out my bar and the oil passages.
So, is there a better way to get tree gunk and dirt off besides diesel? I don't want to use gasoline.
/ Cleaning chains #2
Seen some folks drag tire chains down dirt road for couple miles or so.
/ Cleaning chains #3
Think he is talking chainsaw chains.....
Diesel works - use a scrubbing brush in a old baking pan or if you have a parts cleaner I just put mine in there and scrub them off if they are a mess.
/ Cleaning chains #4
I don't really think dragging chain saw chains down a dirt road would help a lot. I do occasionally slosh mine around in a small bucket of gasoline, let them air dry, then back into a small tub of motor oil. I don't have a better solvent, than gas, available to clean them with.
/ Cleaning chains #6
I never thought to clean the chains, yes the bar and oil passages. I never cut up stumps though, seems it would be good to get any abrasive material out of the chain and diesel has some lubrication properties. I'll have to keep that in mind.
/ Cleaning chains #7
I use WD-40 for cleaning most everything industrial and some things not so industrial.
/ Cleaning chains #8
I spray mine down with brake cleaner, blow them dry and then spray with wd40
/ Cleaning chains
They soaked in diesel 2 days then wire brushed today and back in the diesel, some of that gunk was really stuck.
As for the dirt road, that's kinda how I got here in the first place.
I will look up ed red.
/ Cleaning chains #11
Best way to clean a chain is to put it where it belongs, in the wood.
If you have spare chains that are cruddy, run em clean, then take em off. They should be cleaned and oiled by your oiler. Take your chain and wrap it up in news paper, label it, 32" good, or 36" dirt and store em till you need them. If you hang em up someplace and never use them the dampness sooner or later will get to them.
In the PNW, rust never sleeps.
/ Cleaning chains #14
In the wood best for cleaning a grungy chain
/ Cleaning chains #16
If yer dragging yer thang in the dirt,shame on you. sprockets clean themselves if you are using free floating and not a star.
Bars need to be removed and drug out with a putty knife or one of your chain reflectors or thin knife. put it in the tip end and pull back through the groove in the rail so it exits at the mount end. sawdust compacted with oil, or dirt.
/ Cleaning chains #17
Some of the cheaper bar oils seemed to gunk up on me leaving a residue, I went beck to Stihl's oil.
/ Cleaning chains
Yeah I cleaned bar out, I usually do that periodically.
I have been using Wal mart bar oil. Maybe that's why the fine dirt was so glued on.
I used to use motor oil. I noticed it's not as snot like and flings off too easy.
After soaking and wire brushing I threw them back in the diesel to clean off the mess from brushing. Look good as new.
300 Gallon Portable Fuel Tank (A64127)
300 Gallon...
265/75R16 New Tire (A62613)
265/75R16 New Tire...
23" QUICK ATTACH EXCAVATOR BUCKET (A60429)
23" QUICK ATTACH...
PAN (A62613)
PAN (A62613)
2015 IC Corporation PB105 School Bus (A61573)
2015 IC...
John Deere 4955 Tractor (A66285)
John Deere 4955...
