Chipper Chinese Chipper Review
/ Chinese Chipper Review
Here's the response I got from a long time tractor dealer who has sold and serviced a bunch of these.
"The lower jack shaft may have slid in the bearing blocks some. Did you loosen the 6mm set
screws in the pillow block collars to see if you can drift the whole shaft the 1/2"??? Failing that
,if you loosen or remove the (3) 13mm bolts in the rear of the drive pulley you can remove the pulley.
With the pulley housing removed the collet will expand enough to slide on the jack shaft. The pulleys
are friction fits on both shafts. Sounds like something slipped here."
So the 1st section was the picture that I posted, I haven't even looked at how the drive pulley removal works. I'll take a look at it tomorrow.
DIYGuy (MarkS)
/ Chinese Chipper Review #122
You won't have time to look at it tomorrow...... did you forget that your presence is requested in Sturbridge at noon???? It is the CT TBN group meeting... actually, we will have to do a name change to CT/MA TBN ..... Hope to see a lot more people make it tomorrow.....
/ Chinese Chipper Review #123
DIYGuy,
Thanks for posting this problem over at the CTOA website for me. I was trying to figure out how to register when I noticed that you already posted the issue....thx a bunch.
I have noticed that the pulley key on the lower jackshaft is sticking out about the same amount that the pulleys are misaligned. I will try pulling the pulley as soon as I can round up a pulley puller.
Thx again,
Mike
/ Chinese Chipper Review #124
Guys,
I may be nuts but I believe no one has actually revealed the name of this chipper! I now know that it is too heavy for my tractor but I want to look and see if the company makes a smaller one that still has the auto feed feature. Anyone got a web site for it. Thanks, BW
Jinma manufactures the chipper. They make a 4" model and a 6" model, named "Model 4" and "Model 6". They also go by the names JM-004 and JM-006. I have never seen anybody get a 4" model. Only pictures. My experience is limited to my own Model 6.
The Jinma 224 can handle the 6" chipper. The tractor weighs just under 3000 lbs. with a 3 cyl 80mm bore 22hp motor.
I just updated my web article on the chipper to include more detail on blade removal.
FWIW, I'm not a dealer, just a happy gentleman farmer in the current vernacular.
DIYGuy (MarkS)
/ Chinese Chipper Review #127
DIYGuy, you made a good, helpful web article - But, wondering it didn't come with a user manual?
/ Chinese Chipper Review #128
Well I can answer that one...and save DIYGuy from having to be modest. Yes it does come with a manual and for a Chinese product it isn't the worst I've seen. However, DIYGuy has done a terrific job of adding his experience to the mix as well as filling in some of the "gaps" in the manual. Anyone ever bought anything and said "Wow, this is a great manual"? Probably not. /forums/images/graemlins/smile.gif
/ Chinese Chipper Review #129
Thanks. Was only wondering whether it comes with a manual or not. Yes, he DIYGuy did a good work by publishing his experiences on the web. Changing a part, correcting an error or adding a missed item is much easier on a web manual than a printed hardcopy manual. I think printed hardcopy manuals should disappear after this web thing.
Actually, I didn't get a manual with mine and from what I've been told, I didn't miss much.
DIYGuy
/ Chinese Chipper Review #131
You are correct there. There isn't much in it. It does have an exploded view drawing with part numbers and a parts list. That may or may not come in handy. There are virtually no assembly instructions. It basically says, "Step:1 - Assemble chipper". It would have taken me days to assemble it without the benefit of your web site. Thanks again!
I assembled mine yesterday. A few minor issues and observations. For some reason all of my bearings have only one zerk each where yours has two. I'm not sure why that is. I'd rather have the two.
Another issue is that the feed roller cross connect rod hits the frame when I go to disengage the feed roller. Does yours? From your photos it looks like it might.
Also, on the lift pins, when I assembled the unit I bolted in the bars with the lift pins so they were sticking all the way out which is the way it appeared to me in your photos. When I went to hook up, the drive shaft was too short. I ended up shoving them all the way back. The drive shaft is now connected and I ran it but I'm not so sure it has enough engagement. Did you have any issues with yours?
In any event I ran it some yesterday. It will eat up a bunch of wood in short order! I started out with an oak that was 4" Dia at the base and about 20 feet long. It gobbled the whole thing down like it was candy. They sure are fun to use!
I'm not sure which rod you mean. There's the lever on top, the horizontal member that connects it to the lever to the lever that disengages the feed roller.
The roller itself uses 2 bolts in the side of the hopper as stops to prevent the roller from being lifted to high. The big heavy frame hits these bolts.
None of my mechanisms hit the frame however. A picture would really help.
My shaft and lift pins are set as far back as I could. Although it looks like there a lot of ajustability there, it's really pretty small. I had the advantage that the parts all had dents in the paint from factory assembly. Made it a little easier to put together.
Jinma assembles and tests everything 1st. Then those for export are disassembled and crated.
/ Chinese Chipper Review #133
Well I am curious about what you guys with the Jinma Chipper think about it after using it awhile. I know DIYguy thinks a lot of it and has written some good info for the rest of us to read. Did Ken4210 ever get his back together? He had some problems with that shaft/joint. Would you all buy one again? It seems like just a few people have written in about them so I wonder how many are out there being used.
/ Chinese Chipper Review #134
DIYGuy,
I read your new addition to your articles regarding knife changes. I haven't tried this yet, but if the bolts on the side of the hopper (the roller stops) are removed, the roller could be propped up even further which would allow a hand to be easily inserted from the side of the hopper and under the roller to undue the allen bolts. Instead of using a board to prop up the roller, I have been tying the roller bar to the roller stop controller bar while the roller is in the up position. Next time I have to change the knives I try this method and let you know.
MAJMAC392 - I have about 30 hours on the chipper and I am still impressed on it's functionality. The only issue that I had so far was the drive belt twisted on me. I make this up to not having it adjusted correctly. I am currently thinning 6 acres of pine, juniper, oak and scrub oak and couldn't imagine doing it without some sort of self-feed mechanism. For the money, I think this chipper is the "best buy".
thanks for all your help,
Mike
/ Chinese Chipper Review #135
Majmac392 - I did get mine back together and functioning. Still don't know the exact cause of the problems with the drive joint other than what appeared to be an incorrectly installed retaining ring, and maybe to large of a tree inserted into the chipper. In any event after replacing the retaining ring with one better designed for the application, I haven't had any additional problems with the unit. But in all fairness I haven't been out trudgging through the snow to use it much lately. I would not discourage anyone from buying one of these Jinma 6 units. They work great, have realitively simple mechanics, and are a fraction of the cost of anything else I looked at.
/ Chinese Chipper Review #136
I'm going to look at one this weekend.
A person about 45mi away started to handle them and has 2 in stock.
He said he would assemble and adjust. Also he will take care of all warranty work.
We're still talking price but he may deliver.
After reading all the posts , is there anything in particular I should look for while "kickin the tires" on a new machine ?
GrayBeard
You should be able to turn the machine by hand from the lower pulley on a properly adjusted unit.
Ask to pull the shroud on the roller drive mechanism and make sure that the release lever does indeed separate the square key from the drive roller shaft.
If this is set up properly, then they probably got it right.
They are simple machines. 6 bearings, 3 springs, 1 gear box, two ball and socket joints, 6 belts, 2 knives, and a PTO shaft.
/ Chinese Chipper Review #138
My tractor/loader is about 2500 lbs with 21 pto hp.
Do you think that would handle it ?
GrayBeard
The implement wieghs ~850 lbs. It's always quoted as crated weight of ~900. The crate weighs ~50.
My tractor is about 3000# and if I'n not careful starting uphill, the front wheels will lift, even with 200 lbs of front wieghts.
As long as you can lift it, it'll work. Just be very careful moving it around.
/ Chinese Chipper Review #140
</font><font color="blueclass=small">( I'm not sure which rod you mean. There's the lever on top, the horizontal member that connects it to the lever to the lever that disengages the feed roller. )</font>
DIYGuy,
Sorry for the big delay in responding...been kinda busy. Here is the photo. Steel rod hits and is deflected by the red feeder bar over it's entire travel (when it is disengaged).
