Chipper Chinese Chipper Review
/ Chinese Chipper Review
It looks like the cotrol rods are short. Here's a picture of mine. There's no interferance at all.
/ Chinese Chipper Review #142
</font><font color="blue" class="small">( The toughest part was getting the old ring out. I ended up cutting it out with a small cutting wheel in a Dremel Moto-tool )</font>
Well I started chipping today...about the second hour of use on the machine. My circlip gave out I guess I have to go through the same mess as you were now!
/ Chinese Chipper Review #143
Hey Ken...one more thing. Do you have the exact dimensions on that circlip? I would like to try to find it locally. Thanks.
/ Chinese Chipper Review #144
I checked out a Chinese chipper yesterday.
Are there any visual "checks" to determine if there's going to be a problem ? (feed roller drive)
Or is it just maybe the "weak link" and could fail anytime ?
Thanks,
Graybeard
/ Chinese Chipper Review #145
Hi TonyC - Sorry to hear that you had the same problem as I did. The retaining ring that I used was a 1" OD. This fix only has seemed to band-aid the problem though. Did some serious chipping last weekend, and seemed like I was going through these clips once an hour. Only good part is that it only takes me about 5 minutes to change it out versus the 6 hours it took me to get out the original. I would suggest getting the retaining rings in steel rather than stainless like I did the first time, I don't think they are as tough as the steel would be. I have ordered some steel ones to try out, but also ordered what I hope to be the ultimate fix, replace the factory part with an actual u-joint. It's not a cheap fix @ $35 but if it solves the problem, I'm all for it. It will require a bit of machining, and welding but I think it's worth a try. I'll keep you posted on where I end up on this. It seems to be only the upper joint by the gear reduction unit thats giving me a problem. I did a lot of studying this weekend to see what is causing the problem, and the only thing that I can see right off is that the angle from the gear unit to the feed roller seems to be a bit too steep for the kind of joint they are using. When you are feeding material through the unit everything works like you would expect, the spring holds the joint tight. Where it seems to get into trouble is with small twigs, and branches when the drum is in it's lowest position.
It seems there is something going on with the drive shaft that not all of us run into and while it may seem that I'm the only guy without problems, I'm the only guy without problems AND a computer. /forums/images/graemlins/grin.gif I am one of 3 locally who have these and we all have over 30 hours without issues. There are two dealers within 2 hours of my house, and they are both stumped.
I'd like to really figure this out so the dealers that import these can send a change request back to Jinma.
Is it possible that the ball end of the socket isn't cut down enough? The angle at the gearbox shaft and the roller shaft is the same as the shafts are parrallel. So if only one side is failing all the time, then there is something wrong/different with that end of the shaft.
If it were my unit, I would remove a small amount of material from the ball end of the joint where it is striking the clip before going through the effort of putting a u-joint in. A U-joint will have even a steeper angle to deal with as it will be wider than the current ball and socket joint.
Oooo, that leads me to this last thought, if the drive belt is too short, then the pulley's are closer together and the angle is steeper. I've seen replacement x-refs citing 36, 37, and 38" X 1/2" belts. The longest belt that can be tightened (limited by the slots on the gearbox mounting plate) would seem to be the best belt for the mechanism.
Please keep us informed and if you need any pictures of my unit to help, don't hesitate to ask.
/ Chinese Chipper Review #147
</font><font color="blue" class="small">( Only good part is that it only takes me about 5 minutes to change it out versus the 6 hours it took me to get out the original.
Where it seems to get into trouble is with small twigs, and branches when the drum is in it's lowest position. )</font>
Hi Ken...thaks for the vote of sympathy. /forums/images/graemlins/frown.gif
I haven't tried to get the old one out yet. It looks very ugly.
I thought about that too when you originally said you were getting stainless steel. I built a greenhouse using stainless steel screws and found out first hand how soft it is. That could be your problem.
It's odd what you said about twigs. Mine failed when I attempted to max out the feed roller with a larger trunk. It had been fine up until then. I plan to have a friend of mine look at it. He is a master mechanic (autos) but a good mechanic is a good mechanic, right? I guess we'll see how she goes. I'll keep you posted.
/ Chinese Chipper Review #148
Tony, This is probably a stupid question but have you gone back to ask Gary where you bought the chipper, about the problem? You are at least the second person on the forum, so there are probably more people out there, that have had the problem and just wondering if the Chinese Factory has been told about it and come up with any fixes. They are pretty ingenious folks and I would think they would want to correct the problem. I would almost think you, (or any owner of Jinma equipment), could contact the factory via the Internet directly.
Just a thought.
/ Chinese Chipper Review #149
dsinger,
I don't own one but I keep thinking about the chipper shaft problem. I'm also going to look at a used chipper, the owner thought it was a Danuser but couldn't remember the name. That got me to thinking, I don't think the Danuser is made here in the US anymore but dsinger mentioned the Chinese one looked like a Danuser knockoff. I spent a tour in Korea so I know that they seem to be able to copy about anything. My question is "How does the Danuser chipper's drive work, is it the same type of shaft?" Maybe looking at the Danuser might help fix the Jinma chipper problem or even retrofit it.
/ Chinese Chipper Review #150
DIYGuy/
I am planning on buying a chipper from gary and I am wondering if you are still having problems with yours. would you recommend purchasing one. I have 5 acres of heavy woods so there is always something to chip. I have a kubota bx22 and it rated to lift 1200 pounds at the the lifting points. do you think it will work. I just got the tractor, and I am very inexperienced. any help would be appreciated. I am also looking for a forklift attachemnt.
thanks
chuck
/ Chinese Chipper Review #151
chuckva
I am no expert on the chinese chippers but I suspect it is more than you bx22 can easly handle. Where is the 1200 pound lift capacity rated at the pins or 2' back or? Good luck.
Happy Tractoring
Chipperman /forums/images/graemlins/smile.gif /forums/images/graemlins/smile.gif
PS: What does eveyone else think?
I've had no problems with my chipper outside of normal maint. and would reccomend one to anybody who has a tractor that can safely attach to it. That being said, I think they are little on the heavy side for a BX22.
I haven't run a BX22, only looked at one up close and although the PTO would probably power the chipper just fine, I don't think you'll be able to transport it safely.
FWIW...
/ Chinese Chipper Review #154
I have to agree that the BX would not be able to move this chipper. I have an L3600 and it grunts every time I lift it. There is an identical but smaller Jinma Model 4 Chipper (we all have a Model 6). It weighs in at 675# and is suitable for an 8 to 35 Hp tractor. You can check out the specs here.Maybe Gary can order you one of those. I think the BX could handle it.
As far as the circlip problem, I'll admit it is annoying but I wouldn't give the chipper back for a full refund either. I'll get it settled. For the price Gary sells this unit for, I'd buy it again in a second.
Good luck!
/ Chinese Chipper Review #155
I recently decided that I needed a chipper for my 25+ acres of timber which suffered a bad ice storm about two years ago. I had been leaning toward the DR 3pt chipper, but then I found this thread and I'm seriously thinking of finding one.
I use an old AC WD for farm work, which should have the horsepower to handle this chipper (25 HP at the pto), but I'm wondering about the weight. I've got a 500lb mower that makes the tractor just a hair tippy, so I'm leery of strapping a 800lb hunk of metal to the back.
Anyone have any thoughts about how big of a tractor you really need for this?
jf
/ Chinese Chipper Review #156
</font><font color="blue" class="small">( I've got a 500lb mower that makes the tractor just a hair tippy, so I'm leery of strapping a 800lb hunk of metal to the back.
Anyone have any thoughts about how big of a tractor you really need for this? )</font>
I don't think this chipper is the one for you. It is a very heavy piece of equipment as you know. It actually weighs in at 880#. Technically your horsepower will handle it but I don't think you would be happy with the results. There is an identical Model 4 which is a bit smaller. It weighs 675#. It still sounds heavy for you but certainly more feasible. Go here to see the specs on both.
Good luck!
/ Chinese Chipper Review #157
For all of you who own this chipper:
As you may know a few of us are having a bit of a problem with the feed roller drive shaft. A mechanic friend of mine raised an interesting question the other day. Why is one end of the shaft about 8" higher than the other? The high end is at the small hydraulic motor box. He (and now I) don't understand why this motor wasn't mounted lower so it would be even with the other end of a shaft. Then you wouldn't need a universal joint at all...just a straight shaft. We've looked at it from all angles and can't see why this wasn't done yet we feel there must be a reason. Any thoughts?
The shaft at the feed roller end moves up and down as wood is fed into the chipper. If you pull on the lever to raise the feed roller, it will become pretty obvious how the feed shaft operates while wood is being fed into the chipper.
This is why it is so important that the two sections freely slide against each other.
/ Chinese Chipper Review #159
I just ordered one of the chippers from Emerybuilt. When I first assemble it what can I do to stop the circlip from wearing out?
/ Chinese Chipper Review #160
Only 23 more and this will start over at "0"
