Chipper Chinese Chipper Review
/ Chinese Chipper Review #181
Here is a closeup of the socket. Both half-shafts had the same socket dimensions.
Mark
/ Chinese Chipper Review #182
Here are the balls or "nubs" before I reworked them. After the grinding on the rough one, it looked identical to the smooth one.
Mark
/ Chinese Chipper Review #183
I've been using my Jinma chipper for about 8 months now and found it to be a very useful tool if you don't expect it to do the work of an industrial unit.
I've found a few mechanical issues that need to be addressed by the factory.
1) The feeder drum has dull teeth, as a result it often feeds poorly. It slips on irregularly shapped wood. As a result, the user has to pull twist and refeed some limbs to get them to feed. I believe having dull teeth creates a bit of a safety hazard.
2) The jack shaft coupler slips off the shaft and the shaft disconnects it's self. The feeder drum bearings have a Allen head screw which is to hold the bearing to the shaft. There are no detents in the shaft to hold the screws so, after a time, the support arms spread out pushing the jack shaft coupler off the end of ths shaft. I had to disassemble the feeder drum assembly and drill detents on the shaft. This fixed the problem. This is a bit of a headache.
3) There is a small pulley on the end of the flywheel shaft. This pulley drives the gear reduction unit for the feeder drum. The hole through which the flywheel shaft passes is too large. This allows a build up of bark and wood strips to wrap around the shaft, walk through the opening and build up behind the pulley. Eventually this pushes the pulley off the end of the shaft. Before this happens, it creates a belt misalignment which shreds the belt.
4) When the chipper is not mounted on the tractor and is sitting on the ground, it's unstable and can easily tip towards the feeder chute. At 800 pounds, having this thing unexpectedly tip over on you would not be a pleasant experience. I mounted a set of support arms on the base of the chipper and now it's stable on soft or uneven ground.
As I said, the chipper is a useful unit but it needs a little redesign work. It's not an industrial capacity chipper but will do lots of small work.
Basically, it's perfect for the person who burns wood. Everything it won't chip is big enough to burn in the wood stove.
/ Chinese Chipper Review #184
That's a useful posting, Truchaos. I was on the point of investing in a Jinma 6 chipper. We're clearing an acre and a half or thereby of woodland for a new barn and to relocate our house. From what you say, I'm thinking the Jinma will not be robust enough for the large quantity of material we will have to process but I'd be interested in your view. We'll have a lot to do quickly after the felling then the chipper will be on lighter duties. Am I right in thinking for the heavy work we'd be best to get something with less design problems?
/ Chinese Chipper Review #185
</font><font color="blue" class="small">( We'll have a lot to do quickly after the felling )</font>
I see this as the major obstacle (alot to do quickly) ..... I just cleared a 100' x 100' area of dense woods and chipped the brush with my Jinma (Farm Pro)
I have maybe 20 hours on it ... in that time I had to 1. replace the belt for the feed roller drive (wood shavings coming thru the hole popped it off the pulley and it shredded), readjust/retighten the bearings for the feed roller (they loosened and the feed roller shaft got pushed too far to one side), need to replace the outboard ball and socket joint for the feed roller drive shaft, which has ground itself down and will no longer drive the feed roller. I still haven't got around to doing the last item, but it should be a fairly easy fix (if you weld)
The chipper is a great value for the price (around $1600 or so) - but it does come with a few minor imperfections which will have to be addressed. It is, overall a very heavy-duty piece of gear.
If you are mechanically inclined and have a bit of time and the facilities then it's a good deal. The fact is to get something close in it's capabilities you are probably looking at $4K to $5K at least, maybe more. But if you need to do "alot quickly" then maybe that's money well spent. If I had it to do over again I'd still buy it.
/ Chinese Chipper Review #186
I bought mine last summer and have chipped a lot of yards of mulch. Chipped another 3+yards just last week. I have not had any of the problems you guys are listing.
The feed roller belt has popped off before but only because the roller got jambed up and stopped. I'm assuming the belt starts hopping and pops off after bit. I'm still running all the original belts as well.
It also stays well lubed and dont see any signs of wear on the knuckles or anything coming loose. When getting the chipper I took extra time and went over all the nuts and bolts etc.. Perhaps I just got a good one, maintained it better from the start or not using to capacity 90% of the time. Most stuff is 3" or less.
As far as the dull drum teeth, yea they are dull. I had considered sharpening them but figured it would just add stress in the knuckle. Don't see how this could be a safety hazard. Can't imagine anyone being dumb enough to reach into a running chipper. Use another stick/branch to push it if its in that far. Lift the roller and pull it out if its out past the chute, otherwise turn it off.
/ Chinese Chipper Review #187
Sounds like the machine is good value despite it's shortcomings and, as has been pointed out, the home grown competition is very much more expensive. I'll likely still go for it but carry out the upgrades recommended on TBN before I put it to work.
/ Chinese Chipper Review #188
Looking for up date from you folks who bought the Jinman 006. Still like them? Having any more problems? Did Gary ever help with the shaft problem? Has there been a change from the factor? Thanks.
/ Chinese Chipper Review #189
I bought mine early this year. I've put about 15-20 hours on it and it has work great! I have not had any problems with it. I just took it off my tractor and put it in the shop. I am planning on going though a good servicing prior to using it again next spring. Specifically, I want to check out the feed roller drive system to see how it is holding up. I suppose I should replace the drive belt while I've got it apart just as a precautionary step.
/ Chinese Chipper Review #191
I'm looking at the Jinma and have read many issues with the feed roller assembly. It looks like observations made by Markie61(5/07/04) may have addressed the problem. Did anyone have success with trying his nub reworking suggestion?
I'm located in the San Jose, Ca area and was thinking about buying it through China Best Products for $1550. Don't know if any of you have heard of China Best Products, or not, but am looking for any input/warnings.
Also, I had seen a post of DIYGuy (mark) where he mentioned a modification he made to the 6" chipper - e.g, foot pedal to control the feed. Since seeing that post and many other, I tried to "go back" and look at it again - but I wasn't able to find it. I thought there were some pictures that were going to be posted, but unable to find them. Does anyone know if there are any, and if so, where they were posted?
TIA
Michael
/ Chinese Chipper Review #192
Michael, are you able to pickup that chipper nearby? Or do you plan on paying shipping on top of the $1550?
/ Chinese Chipper Review #193
I sent you a PM about the foot pedal, and the knuckles, we have sold alot of these units with very few problems.If we can help you with anything please let us know.I would confirm a ship date, ordering from China you are looking at 45-60 days.
also ask about tariff fees(yes on woodchippers) warehouse pick up fees, delivery fees, customs.Also check about warranty parts if they have them in stock in the USA, knuckles,blades,inner and outter drive shafts, PTO shafts,.
Tommy
Affordable Tractor Sales
/ Chinese Chipper Review #195
I'd be quite interested to know if you do that deal and how it worked out. I had a very nice email chat with them this morn. They only put a unit in their (Frisco or Oakland) warehouses upon a customer ordering one. Payment must be made in advance of pickup (and inspection of unit) and be made by wire transfer or money order. I just can't do business that way. They do seem like nice, no-pressure folks though.
Cheers!
/ Chinese Chipper Review #196
The interesting thing about Chinese products is that they are getting better and better every day. Don't forget that your money is not going directly to China. There is a middle man, such as Tractorloft, that employs US workers. And Tractorloft and their employees spend theitr money like everyone else...in the US economy on a wide range of products.
/ Chinese Chipper Review #197
I'll keep you posted if I go with them - The main concern I have is in the company China Best Products. The challenge is - how to determine if they are reputable.
/ Chinese Chipper Review #198
I ordered the chipper from China Best Products after talking to others who ordered from them. The cost will be $1565 which includes a spare set of belts and blades. I'll keep you posted on delivery which, if it holds true to what they told me, should be 30 to 40 days from the time funds clear. So far, I've been impressed with their responsiveness to emails - The longest wait for response to my 12 emails has been an hour for the two emails I sent on Sunday. The other emails have been answered within 30 minutes. This will only be significant if they are for "real", and I receive the chipper.
/ Chinese Chipper Review #199
Thanks for the update! Wish you the best with it and looking forward to hearing how you like it!
Cheers!
/ Chinese Chipper Review #200
Homier has them in stock $1299.00, called a Farm Pro, but as I have posted, is the Jinma. Shipping is reasonable. Don't use their estimator. Call them and if you get shipping to business that has lift, very reasonable. See other post about in this thread about good price for chipper. Some of us have ordered within the last week. Takes about a week for delivery.
http://www.homier.com/detail.asp?dpt=&cat=&sku=03175
Brake Drums (A62613)
Land Pride RB3584 3Pt Blade (A66408)
Land Pride RB3584...
3147 (A63117)
3147 (A63117)
2018 Peterbilt 579 Sleeper 72" Sleeper (A62613)
2018 Peterbilt 579...
2016 WANCO WTSP PORTABLE ARROW BOARD (A60429)
2016 WANCO WTSP...
WESTINGHOUSE PORTABLE ARC WELDER (A64276)
WESTINGHOUSE...
