Chipper Chinese Chipper Review
/ Chinese Chipper Review #101
Hi
They are also referred to as an internal retaining ring McMaster carr has them all
Charlie
/ Chinese Chipper Review #102
you might also try jinmaparts.com, not sure of the exact web addy though they ahve been stocking lots of stuff.
Mark M /forums/images/graemlins/frown.gif
/ Chinese Chipper Review #104
TonyC - I've tried to get a better picture of what I'm talking about, but can"t seem to get a good angle that shows it. I'll see if I can make an illustration that will show it more clearly. There was someone else on the post that pretty much hit on what the part is. It is like a snap ring with no plier holes, it looks like a C shaped piece of wire. I did look in the McMaster Carr catalog and thing I found a suitable replacement (see attachment). I think as a replacement it is actually a better choice than the original C clip, when it is installed it doesn't leave an open area for the ball to work against. I've used these spiral retaining rings with two stroke engine pistons before, and they work quite well. I'll give it a try and update everyone on if it works or not.
/ Chinese Chipper Review #105
Oops. forgot the attachment on the last post, Sorry
/ Chinese Chipper Review #106
Thanks a lot Ken. I would be very interested what you think. If it actually works out better I will get some for my chipper right away (if I ever get to pick it up that is!)
/ Chinese Chipper Review #107
TonyC - Well I got in the spiral retaining rings from McMaster Carr. They appear as though they will work much better than the original parts. The toughest part was getting the old ring out. I ended up cutting it out with a small cutting wheel in a Dremel Moto-tool. I installed the new rings, and took it out for a test chipping session, and didn't have any problems after a couple of hours. It was too cold out to stay out much longer than that. I plan on tearing down this assembly again after I run it a few more hours, just to make sure that this solved the problem. This unit sure makes quick work of a brush pile.
The McMaster-Carr # for the rings is #92370 a161. I bought a 5 pc package of stainless steel ones @ $6.20
/forums/images/graemlins/grin.gif
/ Chinese Chipper Review #108
Thanks for keeping me posted, Ken. The big question for me is should I replace my clips before I even start it or should I just leave well enough alone and keep an eye on it. What do you think?
I'd keep an eye on it, and only replace it when necessary. FWIW, Bolton Power Equipment (BoltonPowerEquip.com) stocks a good supply of Chipper parts.
DIYGuy (MarkS)
/ Chinese Chipper Review #110
Guys, sorry to butt in but what do you think the minimum size tractor that could run this chipper? I have a 2000lb. , 20hp pto tractor. bw
/ Chinese Chipper Review #111
No problem, you're not butting in. We share in everything here!
DIYGuy who started this thread is using it on a 22 HP tractor. When I ordered mine they said that 20HP was the absolute minimum. Of course, the more HP the better. My tractor is 31 HP at the PTO so I can't offer a good reference. You should also consider the weight. I believe it weighs in at 800 or 900 lbs.
I can ask my supplier for more info and let you know. Stay tuned.
Good luck!
/ Chinese Chipper Review #112
Howdy,
I am a recent purchaser of this chipper and find it meeting my expectations. I really love the mechanical feed as it minimizes the amount of required material pushing. One question that I do have for the "seasoned" owners of this fine chipper...how does one easily change the blades. I have only done this once and it required another person to help. I would like to figure out how to do this myself.
thx,
Mike
My tractor is 22 hp, and almost 3000lbs. This is the heaviest thing I can imagine attaching to my tractor.
I think a 2000 lb. tractor is really too small for the chipper.
DIYGuy
/ Chinese Chipper Review #115
DIYGuy,
Read the articles before I got the chipper. They where very helpful in getting the chipper assembled and PM'd for use. The problem I am having is how to reach the allen bolt and the nuts at the same time. Does one disassemble the chute to be able to reach both sides of the blade? I must be missing something simple as I can't believe that the designers of this chipper would develop something that required two people to maintain.
thx,
Mike
/ Chinese Chipper Review #116
DIY Guy,
The last post made me start thinking about tractor size. I have a 7234 Cub, 23 HP and it is listed as 20 HP @ the PTO. It weighs around 3300 # with the loader on it. I would assume that would handle the chipper. How many HP is your Jinma at the PTO?
Thanks.
/ Chinese Chipper Review #117
DIYGuy,
Just got done using the chipper for 8 hours or so. When I was doing the 8 hour grease and belt tightening maintenance, I noticed that the drive pulleys are not aligned. The top set of pulleys seem to be about 1/4 to 1/2 inch forward (towards the tractor) than the bottom set. How do you go about correcting the alignment as the belts are groaning as they are.
thx,
Mike
If you look at the bottom set of pulleys, the shaft is held in location by two rings with set screws. You should be able to move the lower shaft by loosening both set screws. This is the shaft that is connected to the PTO Drive and has 5 drive belts to the center shaft that drives the flywheel.
The two set rings are visible in this picture: PTO Shaft Bearings
I have not done this procedure myself, so I can't tell you if this is easy or not.
Posting a question on the CTOA may get a more experienced response from one of the many chinese dealers that inhabit that site.
DIYGuy (MarkS)
As soon as it warms up here (i.e.) gets above 15F, I'll pull the blades and get some additional photos.
I believe the allen head can be accessed through the side of the unit with a socketed allen key and a universal joint, and the the nut side with a deep (17mm I think) socket. Secure the allen head and remove the nut. Be careful not to drop HW into the flywheel shroud.
A 12" bondhaus allen key should also do the trick.
Pictures to come as soon as I can.
Second Note, I don't know what the 224 is rated for at the PTO, however, given the drive line, I don't think it drops off too awful much from the engine. (Direct mechanical drive)
DIYGuy (MarkS)
/ Chinese Chipper Review #120
DIYGuy,
Finally warmed up enough to go out and play. Found the set screws (4) and even after loosening them, couldn't get the shaft to move. Tried "liquid wrench" and still no movement. Tried running the chipper with the screws loose thinking that the belts may move the shaft, but still no movement. I will post over at the other forum to see if I can get some resolution to my problem.
thx,
Mike
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
2009 CHEVROLET IMPALA 4 DOOR CAR (A66091)
2009 CHEVROLET...
2014 Ram Pro Master 2500 Cargo Van (A66736)
2014 Ram Pro...
3pt Steel Hotshot Applicator (A64912)
3pt Steel Hotshot...
Isuzu DEF Delete Parts (A64912)
Isuzu DEF Delete...
2010 48 ROLL OFF TRAILER (A67714)
2010 48 ROLL OFF...
