BX balast box size?
   / BX balast box size? #1
davesl708
Elite Member
Shawnee, KS, USA
Kubota BX2200D,
Hi Group.
I am planning to build a ballast box for my BX2200.
Since the FEL can only lift 460lbs. I cannot imagine the box needing more than 100 to 200lbs.
Does this sound right?
   / BX balast box size? #2
Kubota's suggested counterbalance weight is in your BX Owner's Manual.
   / BX balast box size? #3
From BX2360 manuals:
Loader manual recommends a maximum of 420 pounds on the rear as loader ballast.
Tractor manual recommends a maximum of 275 pounds on the front as rear implement ballast.
Bruce
The manual references tire ballast. I am looking to add ballast to the 3ph for ease of adding or removing.
Bruce
Thanks bcp. I do not have the OP for the FEL just the tractor.
   / BX balast box size? #6
The heavier the counterweight the less stress on the steering\front end. The tractor will spec out what the 3PTH capacity is. I would not go less than 250 lbs. I use 200 lbs on my 12hp B4200 (1,000 lb tractor) for a loader that lifts 400 lbs. Not having power steering, you can feel the difference the counter weight makes. I use about 500 lbs on my B3200.
   / BX balast box size? #7
My tractor loader is rated to lift 1,900 pounds. I have 4,000 pounds of ballast.
   / BX balast box size? #8
I use 50# suitcase weights either front or rear depending on situation. Neat part is the variability to go from 50-500#(I have 10 of them). once you load the tires you are stuck with that weight. A water tank could do the variability but the sloshing around would scare me.
Ron
   / BX balast box size? #9
I love the counterweight that the BH or back blade or rake give me. All are well over 200# and their CG is probably further aft than your ballast box will be. I would size to be compact and ability to load it to about 400lb... maybe a little overkill. I haven't done the math on overhang distance vs. load but if I ever made a ballast box it would be for tight situations when I could not use leave an implement on my 3pt or the BH.
   / BX balast box size? #11
daves1708.......Hi,
Check you e-mail. I've got one to sell.
Cheers,
Mike
2016 Ford Transit 250 Passenger Van (A55852)
2016 Ford Transit...
2019 Deere 35G (A53317)
2019 Deere 35G...
2014 MAGNUM PRODUCTS LIGHT TOWER COMBO (A55745)
2014 MAGNUM...
2017 Ford Fusion Sedan (A59231)
2017 Ford Fusion...
2018 Nissan Rogue SUV (A59231)
2018 Nissan Rogue...
1987 CATERPILLAR D6H HIGH TRACK CRAWLER DOZER (A59823)
1987 CATERPILLAR...
