BH80X Leakdown?
/ BH80X Leakdown? #1
Adiredneck
Upstate NY
2006 Kubota L3400DT, Kubota L5240
I got my BH80X last Friday. I have noticed that if I shut the tractor off for a few hours with the BH up, that it will drop a couple of inches by the time I return. The outriggers also drop a little bit overnight. I always lower the hoe when I park it for the night with the bucket resting on the ground to take the pressure off the tractor.
Is this normal for a new piece of equipment?
/ BH80X Leakdown? #2
Mine has done the same since it was new as well. I keep the boom lock on mine if I won't be using the hoe in the next 20 minutes or so. I put a strap between the stabilizers, an end hooked on each pad, when I park it for the night.
Vic
/ BH80X Leakdown? #3
Vic
me too--
/ BH80X Leakdown? #4
Completely normal, they dont spend the $$ to correctly check valve these things.
/ BH80X Leakdown?
OK. I guess I was comparing it to my loader, which doesn't seem to visibly drop at all.
Thanks!
2023 CATERPILLAR 299D3 XE SKID STEER (A62129)
2023 CATERPILLAR...
2001 FREIGHTLINER FLD120 T/A 6X4 DAY CAB (A59911)
2001 FREIGHTLINER...
iDrive TDS-2010H...
iDrive TDS-2010H...
2023 Takeuchi TL6R Compact Track Loader Skid Steer w Low Hours (A63689)
2023 Takeuchi TL6R...
2019 VOLVO VNL TANDEM AXLE SLEEPER (A59911)
2019 VOLVO VNL...
