BH80X Leakdown?
/ BH80X Leakdown? #1
Adiredneck
Upstate NY
2006 Kubota L3400DT, Kubota L5240
I got my BH80X last Friday. I have noticed that if I shut the tractor off for a few hours with the BH up, that it will drop a couple of inches by the time I return. The outriggers also drop a little bit overnight. I always lower the hoe when I park it for the night with the bucket resting on the ground to take the pressure off the tractor.
Is this normal for a new piece of equipment?
/ BH80X Leakdown? #2
Mine has done the same since it was new as well. I keep the boom lock on mine if I won't be using the hoe in the next 20 minutes or so. I put a strap between the stabilizers, an end hooked on each pad, when I park it for the night.
Vic
/ BH80X Leakdown? #3
Vic
me too--
/ BH80X Leakdown? #4
Completely normal, they dont spend the $$ to correctly check valve these things.
/ BH80X Leakdown?
OK. I guess I was comparing it to my loader, which doesn't seem to visibly drop at all.
Thanks!
2020 KENWORTH T680 6X4 T/A  SLEEPER  TRUCK TRACTOR (A59912)
2020 KENWORTH T680...
2018 F550 Bucket Truck (A63689)
2018 F550 Bucket...
2014 International WorkStar 7300 4x4 Altec AA55E 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2025 ALCOM XPRESS XLT 24FT T/A CARGO TRAILER (A59912)
2025 ALCOM XPRESS...
ROANOKE S/A LOOSE LEAF TRAILER (A63291)
ROANOKE S/A LOOSE...
2006 FREIGHTLINER M2 106 T/A BOX TRUCK W/100 PSIG AIR PUMP (A59912)
2006 FREIGHTLINER...
