tractor tipping question
/ tractor tipping question #81
not familiar with your tractor but a few standard things to counter balance would be - a weight box on the back of the tractor, wheel weights added to rims, and/or load rear tires with liquids like rimguard.
I doubt that a 3pt ballast box would increase his ballast over what his backhoe provides.
Extending the backhoe reach might increase the leverage of the weight, but it could be that his tractor is not weight rated to travel in this configuration.
/ tractor tipping question #82
I have a sub-compact, emax 20s with a bucket and backhoe. A couple of times with a heavy load on the front (clamp on forks) I've felt a rear wheel lift off the ground. Lowered the bucket, inched forward, and lowered the backhoe outriggers to help keep from tipping. Is that a stupid think to do? Does it help?
fill the rear tires with water and a tube,I would not want water inside a tubeless tire
/ tractor tipping question #83
This may sound obviuous but always keep the load as close to the ground as possible when moving a heavy load. If you do need to lift it keep in mind for every inch it goes up the payload weight must go down. Adding forks accelerates the load derating. There are ways to compensate as many of the guys have mentioned but with those, how much counter weight is enough before reaching other limitations? It is all a balance, sort of a see-saw actually.
Another technique you may be able to use is to not completely lift the load off the ground but enough so you can scoot it to where you want it.
/ tractor tipping question #84
Branson 3510i here, got more steep ground than level, hard to find a place to park it where I can properly check the oil level. As configured from the dealer, didn't take much to get two wheels up off the ground, especially when using the FEL. Eventually figured out I could flip the tires around (and then swap left and right to still have forward tread) giving it a wider stance, this solved the problem. They get configured for shipping at minimum width so they can fit more tractors. For an even wider stance, you can buy spacers to place between the hubs on the tractor and your wheels. I find a wide stance to be far more important than playing with weight distribution to keep the tractor from tipping. Use that seatbelt!
/ tractor tipping question #85
I made a quick attach weight for my subcompact Kioti so I could do any loader or forklift work without the rear wheels lifting off the ground. I've upgraded to a compact Kioti but I still find it helps a lot when I'm doing a lot of loader work. I've never weighed my weight but I'd guess it is about 300-350 pounds. It makes loader work fun.
I made it buy welding 7 3" thick by 8" diameter round solid steel wheels together and placing and welding cat 1 lower arm pins that allows me to load and unload weights by using my car 1 3 pt hitch quick attach connection.
If I had a backhoe attachment, I would try to add some quickly removable weights down as low as possible.
Some say adding beet juice to your rear wheels is the best solution and may work better then physical weights. I haven't done that yet so I'm unable to comment from experience on that
Good luck, I'm sure there's a solution out there for you.
/ tractor tipping question #86
you are trying to lift too much weight on the toy tractor loader and the forks sticking out make more leverage. This is called a lazy man's load. Take smaller loads and problem solved.
/ tractor tipping question #87
I run bucket forks on my tractor most of the time. There are good things and bad things about the forks.
Good:
* They can hold the load in one place, and on top of the bucket rather than dangling below (which can throw the balance off if the load swings to the side).
* Good solid tie down places.
* Increases area available to load.
Bad:
* The forks when attached to the bucket are about 2' further out than if I had a fork carrier, pushing the load further forward, and putting more leverage on the front wheels.
* The forks (old forklift forks) are massively heavy. So I probably lose 400 lbs or so of weight capacity just with the forks.
* Mine are fixed location. I put them narrow to carry a tree, but wider would have been better for many things.
* And the forks allow me to add weight 3 feet or so in front of the bucket, further pushing the balance point further.
Overall, I like having the forks. Rear ballast helps a lot. I don't think they negatively impact hill performance. However, I've mentioned before that I've added front axle stops to keep the front axle from rolling to the side with the bucket filled.
So, having the bucket cause the front axle to roll on a hillside could mean dire consequences.
/ tractor tipping question #88
I had a set of bucket forks when I first got my tractor, I used them once, and almost damage what I was lifting when they moved so I scrapped them and bought myself a real set of attachment forks.
I have never regretted it
/ tractor tipping question #89
My forks are bolted to the bucket with 6 grade 8 bolts per fork. They don't move at all. Even less movement than might be expected with regular forklift forks.
/ tractor tipping question #90
Maybe this has been mentioned, but I think some people forget one very important fact. When your back wheels come off the ground, ALL of the weight on the back of the tractor, ALL of the weight on the front of the tractor, PLUS the load in or on your bucket, forks, ALL the weight is on the front wheels and tires. it exceeds the maximum weight the front axle and wheel tires by double or triple. Maybe more than that even. I know this because I do stupid things sometimes. Sometimes I get by with it. Sometimes it costs me..:oops:
/ tractor tipping question #91
Yup. Plus, when that happens, the load is dynamic, not static, meaning things are under even more strain.
/ tractor tipping question #92
And in the end, remember the teeter-totter principal you learned in elementary school....
And as rear wheels come of ground you probably lose forward and backward motion and brakes....
/ tractor tipping question #93
Ah, any dents or anything will buff right out.......:cautious:
/ tractor tipping question #94
precisely, and fwiw the letters SWL printed on the machine actually mean something rather than something some random bored passing by teenage graffiti artist decided to "tag"
/ tractor tipping question #95
Well, not exactly... With 4x4, one can walk on the front wheels, and at the speeds I travel, stopping never is a problem (except for a couple of downhill slopes). Perhaps the rear brakes transfer through the differential.
However, once you lighten the rear wheels enough, steering becomes very problematic as the steering really needs a good rear point of contact, and the tractor just doesn't go where one wants it to go.
Angles are also critical. So, I had one load of steel that seemed to be doing OK, but the tractor veered to the left down a very slight incline on its own, and I rapidly went from balanced with rear wheels on the ground, but a little floaty feeling to the bucket dropping to the ground and the rear wheels high. Rather disconcerting but no real danger since the front axle is blocked from tilting, and the bucket wasn't up that high.
I think if I had headed up the hill I had planned, it would have shifted the weight back and I'd have been fine, but it was much better that I changed my load in a relatively flat area rather than on the hill.
Still, it is a good reminder to keep the ballast on the tractor.
2026 MACK GRANITE GR64F DUMP TRUCK (A63276)
2026 MACK GRANITE...
Gehl 970 Sileage Wagon (A66408)
Gehl 970 Sileage...
INOP/NON-RUNNING EZ - GO Golf Cart (A65579)
INOP/NON-RUNNING...
2015 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A59228)
2015 Chevrolet...
AUCTION STARTS HERE @ 9AM (A65053)
AUCTION STARTS...
250 Gallon Diesel Fuel Tank w/ Pump (A64047)
250 Gallon Diesel...
