BH80X Leakdown?
/ BH80X Leakdown? #1
Adiredneck
Gold Member
Upstate NY
2006 Kubota L3400DT, Kubota L5240
I got my BH80X last Friday. I have noticed that if I shut the tractor off for a few hours with the BH up, that it will drop a couple of inches by the time I return. The outriggers also drop a little bit overnight. I always lower the hoe when I park it for the night with the bucket resting on the ground to take the pressure off the tractor.
Is this normal for a new piece of equipment?
/ BH80X Leakdown? #2
Mine has done the same since it was new as well. I keep the boom lock on mine if I won't be using the hoe in the next 20 minutes or so. I put a strap between the stabilizers, an end hooked on each pad, when I park it for the night.
Vic
/ BH80X Leakdown? #3
Vic
me too--
/ BH80X Leakdown? #4
Completely normal, they dont spend the $$ to correctly check valve these things.
/ BH80X Leakdown?
OK. I guess I was comparing it to my loader, which doesn't seem to visibly drop at all.
Thanks!
2014 International Garbage Truck (A61573)
2014 International...
EZ Go TXT Golf Cart (A61166)
EZ Go TXT Golf...
2022 John Deere 6R 130 Tractor (A63111)
2022 John Deere 6R...
2010 Massey Ferguson 2625 (A60462)
2010 Massey...
2002 Vermeer SC252 Walk-Behind Stump Grinder (A61572)
2002 Vermeer SC252...
FRONT MOUNT BLADE W/ MOUNTS (A63291)
FRONT MOUNT BLADE...
