Barn doors??
/ Barn doors?? #1
AlbertC
Perry, GA
New holland 3930
I have the attached barn and as you can see it has no door. I have seen sliding barn doors but as you can see beside the door is an open wing, so I would not be able to put any hardware on the bottom of the door.
Anyone have any ideas as to haw I could attach doors to this barn? I don' t really want swinging door because I think they would sag. Also, can't put up any type of roll up door because there is not enough room above the door.
Thanks
/ Barn doors?? #2
The only thing you'd need on the bottom is a stay roller which could be attached to the post(s).
I'm presuming that the only opening that you are seeking a door for is the center one.
/ Barn doors??
Thanks. I just assumed that I had to have hardware all across the bottom of the door.
/ Barn doors?? #5
You have several options depending on your future planes for the building,
1) a single track full span and either a large single door or smaller double doors with the option of one each way or both one way.
2) a double track fullspan, if you ever anticipated closing in either side both outside could have doors with the center being on the outer track can roll either way and the outers can go in.
a single track you would be restricted to the number of doors you could operate, with double it would be up to you.
/ Barn doors?? #6
I'm going to buck the trend here and suggest that you likely will need something to keep the bottom in check at the other end when open. Otherwise, there's nothing to stop the wind from moving it around at that end. With the open sides, the wind will be hitting that giant sail unabated, unlike a door sliding open in front of a wall. Rollers will do fine on the inside posts, however, that's probably not feasible on the outside ends. You could always place something as simple as a couple of cinder blocks out there that you can slide the door between. They would hold it in place, and yet still be moveable to have complete access to the open wing areas. :2cents:
/ Barn doors?? #7
The door stop hardware low down on the outer posts would do that.
Bruce
/ Barn doors?? #8
A track at the bottom ices up in the winter and makes it difficult to use the doors. You can install rods in the ground tat catch the outer side of the door to provide some lateral support at the bottom of the door.
/ Barn doors?? #9
I'd do a double track and rollers on the posts to keep the doors from blowing outwards, and stop brackets at the ends to keep from going off the track and also hold the doors from swinging out. The rollers would work even when the doors are only partially open, the stops only work when they're fully open.
/ Barn doors?? #10
Could try something like this.
Fastened at outside edge like a bi-fold closet door. Inside edge rides in a barn door track. Well supported, shouldn't sag. Can open in or out.
/ Barn doors?? #11
I vote double track with door stop hardware. I did basically the same thing and it works great. The hardware at the bottom is only located such that when the door is fully opened or fully closed there is a "blocker" to keep the wind pulling the door outward. Don't put track along the bottom, it will just be a pain.
/ Barn doors?? #17
How big is your opening? I would put a header across the top of the opening and get a garage style roll up door. Everything else will just be hokey and a never ending challenge to maintain.
/ Barn doors??
I don't have enough room above the door to install a roll up door.
/ Barn doors?? #19
Just keep it in mind after you consider all the other options. You can have a door made to any size and a garage style door doesn't need as much room as a roll up door.
/ Barn doors?? #20
Thanks
What opening height do need?
Are you familiar with low headroom overhead doors?
And then there is the old fashioned tilt up door and a thread: http://www.tractorbynet.com/forums/build-yourself/332257-new-shop-door-2.html
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
Unused 2022 USA Attachments EB1024 24in. Pin On Bucket w/ Teeth Excavator Attachment (A66734)
Unused 2022 USA...
2001 Generac SG0060 75kVA Natural Gas Generator (A66734)
2001 Generac...
2013 WACKER NEUSON LTN8 LIGHT PLANT (A68842)
2013 WACKER NEUSON...
CASE TV380 (A67714)
CASE TV380 (A67714)
2025 Swict 78in Bucket Skid Steer Attachment (A66734)
2025 Swict 78in...
